#82321
Fri Jul 20 2007 04:54 AM
Posts: 2,131 Likes: 76
Posts: 2,131 Likes: 76 |
The POTM for July is Tokheim 39 Talls. There are numerous versions of this pump. The Tokheim 39-ESP was produced between 1938 and 1958, and was a computer pump with a hanging hose. The Tokheim 39-HR was produced between 1939 and 1958, and was a four add glass panel pump with a hose on a reel. There was also another Tokheim 39-HR produced between 1948 to 1951, which was a two add glass panel pump with a hose reel and roller guards near the bottom. The Tokheim 39-WNC-HR was produced between 1939 and 1958, and was a two add glass panel pump with a hose reel. The Tokheim 39-WNC was produced between 1939 and 1958, and was a non-computing pump with two add glass panels and a hanging hose. The Tokheim 39-SL was produced between 1939 and 1958, and was a two add glass panel pump, with a stationliter. The Tokheim 39-TW was produced between 1939 and 1958, and was a Tidewater special pump, with four add glass panels. It also had a all glass globe. I have also seen a Tokheim 39-VP with two and four add glass panels, and hanging hose. A Tokheim 39-WNC-VP, which was a non computing pump with four add glass panel, with hanging hose. For the breakdown of the pump I will do the Tokheim 39-VP two and four add glass version. I have seen two different bases for this pump. The upper base is cast and was used on the four add glass pump. The one on the bottom is steel and was used on the two add glass pump. Someone cut a piece out of this base on the upper right corner. The bases are 19" X 24". The door latch assy. on the top is used on the cast base. The one on the bottom is used on the steel base. The pivot point goes on the side with the hose outlet. [This message has been edited by gatorgaspumps (edited 07-20-2007).]
#82322
Fri Jul 20 2007 05:18 AM
The picture on the top shows the legs which are 69 3/4" long. It also shows the frame top and short stabilizer bars. The picture on the bottom shows how these pieces fit together on the top. The hinge brackets go on the side with the hose outlet. This is the light assy., with push button on and off switch. The push button goes on the side with the hose outlet. [This message has been edited by gatorgaspumps (edited 07-20-2007).]
#82323
Fri Jul 20 2007 05:28 AM
#82324
Fri Jul 20 2007 05:41 AM
I have seen two different hinges on the tall 39. The one on the left is the normal one found on the pump. The one on the right is a two-piece hinge and is usually found on some 39 short pumps. I have seen this hinge on a tall pump but some one might have used it after breaking a hinge. There is a right and left hinge, as shown in the picture. The pictures shows the pieces that hold the meter to the frame. The picture on the top shows the cast style that is used on the four add glass pump. The picture in the middle and on the bottom shows the one used on the two add glass pump. The single mount side goes on the side with the hose outlet. [This message has been edited by gatorgaspumps (edited 07-20-2007).]
#82325
Fri Jul 20 2007 05:53 AM
The top picture shows the nozzle hanger and shut off. The bottom picture shows the turn back assy. The doors are 70" long and are not interchangeable from front to back This picture shows the brackets used to hold the front window and add glass to the door. The rubber spacer that I have removed between the door and glass was round stock, and I use a clear stock, you can pick up at most hardware stores. Some people have started using the R101 channel rubber for the spacer. [This message has been edited by gatorgaspumps (edited 07-20-2007).]
#82326
Fri Jul 20 2007 06:09 AM
#82327
Fri Jul 20 2007 06:19 AM
This is the top with the trim piece. Well that's it for the breakdown, now lets see some pictures of pumps. I would be glad to post any pictures for you just send them to me. Richard [This message has been edited by gatorgaspumps (edited 07-20-2007).]
#82328
Fri Jul 20 2007 06:34 AM
I might have had too many silver bullets when I took this picture. The color code for this pump is PPG DCC 11457 Blue, 80808 Yellow The color code for this pump is PPG DCC 70184SC Red, and DCC Black The color code for this pump is PPG DCC 70184SC Red, 43706 Green [This message has been edited by gatorgaspumps (edited 07-20-2007).]
#82329
Fri Jul 20 2007 06:43 AM
The color code for this pump is PPG DCC 90990 White Vanilla, the yellow was a mixture of several yellow colors. The color code for this pump is PPG DCC 18270SC Blue, and 82773H Yellow. [This message has been edited by gatorgaspumps (edited 07-20-2007).]
#82330
Fri Jul 20 2007 08:40 AM
Posts: 1,970 |
Richard, don't worry about the bullets, they're good for ya!!!!! Nice work buddy!!
#82331
Sat Jul 21 2007 10:23 PM
Posts: 3,622 Likes: 1
Posts: 3,622 Likes: 1 |
Very nice work Richard. I like 39's. Of course it was my first. I have an adapter to turn the computer. I love the sound of the bell and the clicks as it turns. One of my projects is to mount a motor to turn it rather than my drill. There was some discussion about that a few months back. I am in need of a Chevron Supreme globe for it but the colors of the Derby Star work for now. Mike
#82332
Sun Jul 22 2007 08:56 AM
Posts: 2,086 |
A rough 39. Jack R
#82333
Sun Jul 22 2007 07:37 PM
Here is a 39 from Savinsam. Great looking pump. Thanks Mike and Jack R for your posts, gotta love those 39's. There has to be more out there lets see some pumps. Richard
#82334
Sun Jul 22 2007 07:51 PM
Posts: 1,669 Likes: 13
Posts: 1,669 Likes: 13 |
You forgot about the Cast Aluminum Base. I have two 4 ad glass models, one with Cast Iron Base, one with Cast Aluminum Base. I also have a 2 ad glass with the stamped steel base.
KJV Psalms 16:11
#82335
Sun Jul 22 2007 09:01 PM
Mike thanks for the info, I've never run accross a cast aluminum base for a 39, is it the same mold as the cast steel? There has to be more differences on these 39's, has anyone else run accross something different? Keep the posts comming. Richard
#82336
Mon Jul 23 2007 04:21 AM
I will take a photo of my cast aluminum base this evening and post it. I think it is the same as the cast iron but haven't inspected that close.
KJV Psalms 16:11
#82337
Mon Jul 23 2007 01:30 PM
Cast Aluminum base.
KJV Psalms 16:11
#82338
Mon Jul 23 2007 08:50 PM
Posts: 598 |
It's been a few years since I posted a pic of this pump, it's a tall 39 with three ad glass, all sides except for the hose side. Before I restored it the panels looked to be original to the pump. Globe is an original. Vern
#82339
Mon Jul 23 2007 09:25 PM
Mike thanks for the picture, looks like the same mold as the cast steel, and takes the same door mech.. Vern great looking pump and wish I had the globe. Maybe they felt the add glass would get broken on that side. Keep the pictures comming. Richard
#82340
Sun Jul 29 2007 07:40 PM
Here are a couple more images. Richard [This message has been edited by gatorgaspumps (edited 07-31-2007).]
#82341
Mon Jul 30 2007 08:56 PM
Here are a couple more 39's. Richard [This message has been edited by gatorgaspumps (edited 07-31-2007).]
#82342
Tue Jul 31 2007 06:41 AM
When did the 39 switch from the aluminum face plate to the porcelain? I have also noticed some of the porcelain face plates that have the black around the gallon & price numbers. Mike
#82343
Thu Aug 02 2007 04:11 PM
Posts: 1,479 |
Mike,
Very good question!!! I would like to know the answer to that too.
Travis E. Towle Topeka, Kansas
785-357-1004
#82344
Sun Aug 05 2007 06:52 AM
Posts: 1,023 |
#82345
Sun Aug 05 2007 09:16 AM
Posts: 54 Likes: 2
Posts: 54 Likes: 2 |
Shot with DSC-W5 at 2007-08-05 A couple of 39SL's that I have.
#82346
Sun Aug 05 2007 10:07 AM
Mike and Travis, wish I could answer your question. All I know is that the Aluminum face plates were early and that the sight glass bezel had Sight glass must be full before and after use on them while the porcelin ones were plain. Maybe some one else can come up with the answer.
Great looking pumps Tokheim and KD, keep those pictures coming. Richard
#82347
Mon Aug 06 2007 09:45 PM
Posts: 4,160 |
Great Job on POTM Richard. thanks everyone for sharing. I used to have 2 tall 39's but traded them. Nice pumps !!!
------------------ Hubba: GAS GEEK , OIL FREAK and humble moderator
#82348
Thu Aug 16 2007 07:52 PM
Posts: 127 |
I have a 39DP clockface DATED 1-39 . How rare is this pump?? [This message has been edited by briansbodyshop (edited 08-16-2007).]
WANTED: TOKHEIM NOZZLES
#82349
Thu Aug 16 2007 09:35 PM
Nice pair of pumps. The clock face pumps show up now and then but not to many around that I know of. Nice thing about it is most of the parts are interchangable from the computer pump from what I know. Would be interested to know what is different besides the clock Meck. between the two. Richard
[This message has been edited by gatorgaspumps (edited 08-16-2007).]
#82350
Fri Aug 17 2007 05:14 AM
Posts: 127 |
These pumps are identical except for a small hole on the side panel on the clock pump to reset the clock,and the frame where the clock unit mounts, is wider than where the computer pump mounts are.If you sit a computer in the clock pump frame,you can only bolt up 2 places instead of 3..The frame is 1/2 inch wider on 1 side in this area..Thanks.Brian.... [This message has been edited by briansbodyshop (edited 08-17-2007).] [This message has been edited by briansbodyshop (edited 08-17-2007).]
#82351
Fri Aug 17 2007 08:28 AM
Great pictures and info, always wanted to know the difference. Thanks Richard
#82352
Sun Aug 19 2007 06:06 AM
Posts: 1,023 |
#82353
Sun Aug 19 2007 07:28 AM
Great pictures Tokheim, thanks Richard
#82354
Sun Aug 19 2007 07:51 AM
Posts: 658 Likes: 3
Posts: 658 Likes: 3 |
Here is a picture of a Cliff Brice station in Pueblo,Co. [img]http://im1.shutterfly.com/procserv/47b7d636b3127cceba6f66aedf7300000025108AbuWTho3ZNL[/img]
#82355
Fri Sep 07 2007 05:29 PM
Posts: 892 |
Wanted to tag this thread as I just finished this 39 Tokheim. I could have used Doc on this one. Reflection, light... Mick [This message has been edited by aquartlow (edited 09-07-2007).]
#82356
Fri Sep 07 2007 07:25 PM
Nice pump Mick, thanks for posting. Richard
