#768427
Mon Sep 13 2021 10:26 AM
Posts: 166 Likes: 6
Posts: 166 Likes: 6 |
I'm new to the site, I've looked around and found all kinds of opinions about restoration and touch ups. What about REPAIRS? I traded around and picked up this Phillips 66 sign. It's an original made by Veribrite Chigago. It's rougher than a nite in the county lock up. My plan is to repair the top corner, and leave the rest alone. Would this help the value, or hurt it?
Posts: 423 Likes: 25
Posts: 423 Likes: 25 |
Welcome to the OG group. Although things are only original once, IMO the sign in the current condition has minimal value because of the scope of the damage. If your display of signs included overlapping corners or edges of other signs, then this sign becomes much more presentable. However if you wanted to experiment with repairing it, the experience may be enjoyable. I don't believe the sign value varies significantly either way. Many of the OG members still have their first signs and first pumps regardless of condition or rarity. Enjoy the hunt.
Posts: 1,871 Likes: 48
Posts: 1,871 Likes: 48 |
Welcome to Oldgas, should you decide to repair please post your process. We always find these interesting.
Posts: 166 Likes: 6
I will definitely be repairing it. Where would I post my "repair thread" at?
Posts: 8,513 Likes: 293
Posts: 8,513 Likes: 293 |
I will definitely be repairing it. Where would I post my "repair thread" at? Your repair story and pictures would be great right here in General Petroliana Discussion, but you could also put it in Showcase & Stories. Your choice. We'd love to see the process.
Posts: 3,739 Likes: 87
Posts: 3,739 Likes: 87 |
Keep in mind that any welding on the sign will cause localized heat and cause the surrounding porcelain to chip off the base metal.
And it may warp the sign itself.
Posts: 166 Likes: 6
Jim Thank you, I plan on welding a corner back on. I'm gonna try to spot fill with my wire welder and butt weld clamps, while cooling it with a wet rag. Somewhere I read that porcelain is cured at around 400 F. The porcelain should stand the heat.....I hope.
It's not the heat so much.
It's the difference in expansion rates between the steel and the porcelain.
The steel will expand quicker than the porcelain.
Causing the porcelain to fly off the steel.
BTW , porcelain fires at 1,450 degrees.
Posts: 166 Likes: 6
BTW , porcelain fires at 1,450 degrees. In the words of Lloyd Christmas, " Man, I was way off!!!!"
Posts: 166 Likes: 6
So.. I started on my sign project the other day. I don't want to restore it, just make it presentable. This is my process, it's probably different from everyone else's.
Pic 1. I cleaned the torch slag off with a hand held grinder.
Pic 2. I found a piece of sheetmetal and trimmed it to fit by tracing the top crown and then I lined it up on the torched side and traced along the torch cut.
Pic 3. I welded it in and ground my welds smooth, I kept the heat low and used a wet rag to cool it, so as not to ruin the porcelain.
Pic 4. A little body work goes a long way. Primed and ready for paint.
Posts: 341 Likes: 3
Posts: 341 Likes: 3 |
Wow! Very good. You have talent! I look forward to seeing the final product.
Posts: 166 Likes: 6
Now that the metal work was over, it was time for masking and paint. I had some orange and black rattle cans in the paint cabinet , so I decided to use them. The shades didn't match, but at least it is the right colors. I traced the letters on wax paper from the good side of the sign. I then layered masking tape on the wax paper and cut the letters out by flipping the paper over and following the lines with my scissors. This made it really easy when it came masking the letters off. One layer of orange paint covered by a layer of black and this is what we have.
I plan on sanding the black with 1500-2000 grit to dull the gloss a bit
Posts: 19,471 Likes: 1022
Posts: 19,471 Likes: 1022 |
xlnt work, looking good .. ...
Posts: 93 Likes: 2
Posts: 93 Likes: 2 |
Posts: 1,302 Likes: 96
Posts: 1,302 Likes: 96 |
impressive work. You ain't lazy!!!
Posts: 166 Likes: 6
xlnt work, looking good .. ... Wow! Very good. You have talent! I look forward to seeing the final product. Thanks for the kind words
Good for you! So far great. You’re my kind of guy, they say it won’t work and you say yes it will. Totally enjoying this post.
Posts: 1,306 Likes: 32
Posts: 1,306 Likes: 32 |
Well done! Rub the new paint with some 0000 steel wool to dull the gloss and it will blend in nicely. Great work.
Well Done, as others have noted, you have skills.
Posts: 2,786 Likes: 165
Posts: 2,786 Likes: 165 |
Posts: 406 Likes: 33
Posts: 406 Likes: 33 |
Yup, great job. Thank you for sharing.
Randy
Posts: 341 Likes: 3
WOW! Awesome. Might as well do the rest of the hits on the sign. You have the ability!
Posts: 2,004 Likes: 59
Posts: 2,004 Likes: 59 |
Posts: 15,631 Likes: 455
Posts: 15,631 Likes: 455 |
Came out nice, thanks for posting.
Posts: 707 Likes: 17
Posts: 707 Likes: 17 |
Posts: 15 Likes: 4
Posts: 15 Likes: 4 |
Thanks for sharing, I like the work you did with this sign, very nice result
Posts: 1,165 Likes: 44
Posts: 1,165 Likes: 44 |
Excellent repair ! Craftsman for sure .
