#757697
Tue Dec 01 2020 04:50 PM
Posts: 1,165 Likes: 44
Posts: 1,165 Likes: 44 |
Can anyone provide a picture of what tag went where these two holes are on this pump ? Thanks for the help . Would like to find an original if someone has one also .
Posts: 2,785 Likes: 165
Posts: 2,785 Likes: 165 |
I will look at mine tomorrow I dont recall seeing any holes in mine where you are showing.
1 member likes this:
buzzy56 |
Thanks appreciate it . I looked thru a lot of 150 images and can’t identify a brass tag that goes there . Serial tag is present , Bennett tag is present . The holes didn’t show until after sand blasting and powder coat . Old paint and surface rust covered them . Every other item was attached to the pump , hose , nozzle , visi gauge all except the globe and that set of holes where some type of tag went .
Posts: 2,131 Likes: 76
Posts: 2,131 Likes: 76 |
I've never seen anything on that location of the pump before. Some company may have but an ID serial number tag there. Richard
buzzy56 |
The holes are so small they would be rivet holes and unthreaded .You do not really notice them from 2-3 foot away but it bugs me and probably always will . Like it is not complete unless i plug those buggers. LOL .
My top skins are original so will find out tomorrow if I have them holes
buzzy56 |
Posts: 1,663 Likes: 25
Posts: 1,663 Likes: 25 |
I’ve never seen anything there on a 150. Maybe it was a standard oil pump & it had the small brass tag that standard used on everything???
buzzy56 |
It was and still is a standard oil pump and standard oil placed a brass tag on it riveted to the top castings with their name et’c. Per close up of this image .
Posts: 2,995 Likes: 109
Posts: 2,995 Likes: 109 |
I have four 150’s and a EMD 450, I’ll check them all tomorrow.
buzzy56 |
Posts: 1,747 Likes: 42
Posts: 1,747 Likes: 42 |
buzzy56 |
It was more than likely the ms brass tag standard used on all of there equipment to keep track of maintenance & catalog there equipment. I hav some & can take pics if necessary. It is a different tag than the one you pictured
buzzy56 |
I checked mine has no holes
buzzy56 |
I have four 150’s and a EMD 450, I’ll check them all tomorrow. Just an FYI: None of my 150’s / Bennett clocks (132 & 450) have those holes.
buzzy56 |
See my post above showing the standard oil co. id tag thats riveted to the pump casting . Must be they decided to place one on the upper sheet metal cabinet also as the hole spacing is pretty close to the one on the casting . Just couldn’t see any reason why they would put one on the cabinet when the standard brass I’d was already riveted to the pump main frame shroud casting . Thanks
Thanks if not too much trouble please do . If the spacing of the rivet holes look similar and the tag is different i will have to hunt one down . Thanks for your input .
Here is one of the tags standard oil used on almost everything they owned. The rivetes are 1 & 5/8 apart
buzzy56 |
Thanks so much that is the exact distance hole to hole . So that is the missing clue /brass tag ! Really appreciate you solving this little mystery that has been bugging me since i finished the pump .
No problem! I may hav an extra one, let me look.
Found it, send me your address & I’ll put it in the mail to you.
buzzy56 |
Chris i Want to thank you for your generous offer of the brass id tag . Received it in the mail today . Gave it a slight oh so slight buff and going to get it out on the pump as soon as I go thru my brass screws and find the correct size . So thanks again Bob
Posts: 899 Likes: 43
Posts: 899 Likes: 43 |
I really enjoy seeing one Old Gasser helping another completing a pump and preserving history. It isn't all about making a buck!
buzzy56 |
That is why this site is still the best site out there ! Old school showing respect ,honesty and a willingness to help one another . More knowledge here than a book could ever capture .
Posts: 108 Likes: 4
Posts: 108 Likes: 4 |
Just curious if you went with reman or original globe ? Looking for one or the other myself...If it is a reman.... does it look good lit up ? What is the durability of the paint on those ?
Nice pump I would like to find on like it
Posts: 3,739 Likes: 87
Posts: 3,739 Likes: 87 |
Quality reproduction lenses are made exactly like the originals - so they will last as long as originals.
Not the acrylic lenses, those are worthless (IMHO), but the reproduction glass lenses are a better choice for a pump restoration.
Nothing looks worse than a high end paint job with a washed out globe sitting on it. Again IMHO.
Like Jim said Complete restoration go with a after market reproduction glass lens and metal globe body painted to match your pump .If it’s going to be an Outside pump reproduction for sure . Don’t want hail ,or rock throwing kids or with a BB gun for Xmas taking it out .. If inside your house original would be nice but pricey .Mine is aftermarket and use them on all my outside pumps . Original globes kept safely inside for display .
Lit up ! Had to put a lower watt bulb in it (now) it was a little too bright and overshadowed the price window . These pictures were before I changed to a lower watt bulb .
Posts: 4,880 Likes: 50
Posts: 4,880 Likes: 50 |
Beautiful Bob!! I don't know about those crown globes, but I put 40W equivalent LED in all my globes. Works out great. And no heat with the LED. And they last basically forever.
Thanks .Yes that is what I put in all my other pumps 25 watt glare reduced led . With the crown being bigger I started out with a larger Led but was too much and I was also out of the smaller wattage and i had to order a couple boxes of lower wattage .The pics are with the first bulbs & since switched out to lower . Just haven’t taken any new pictures. Have been slowly changing all my bulbs to led even outside security lights .
Posts: 108 Likes: 4
Who does the repro the embossed globe...Seems 2 b harder to find ?
Posts: 108 Likes: 4
I found Christmas tree size led bulbs @ Menards they also have the socket ....avlible in different colors....not overpowering and cost only a few cents a month
I don’t know of anyone re producing the raised embossed crown currently . Big cheese does the colors in non embossed but his listings only showed the regulars in colors .
Posts: 108 Likes: 4
I was back and forth on eBay 2 weeks ago on 1.. Seller would not say if it was a repaint, so I got spooked... It went $430 ?
I tried those in my clocks for awhile with the socket reducer and the Xmas tree size lights. I found that the bulbs did not last as long as the regular base LED’s . Had the full size LED’s in my pumps outside for several years now and have not had to replace any of the full size yet . Small base bulbs I was changing about once a year on my clocks . . Although I light up my clocks 24-7 also rather than dusk to Midnight on my pump lights that are on timers .
