#756334
Fri Oct 23 2020 09:12 PM
This is my Wayne 71 that was built from a couple Wayne 70s and reproduction Wayne 71 parts. I built the inside parts to make it look like an original pump but not exactly like a 71. I did get help from an oldgasser with the computer brackets. They are recasts of originals. The first pictures are of the outside. I will post insides later.
1 member likes this:
Oldgas |
Posts: 2,172 Likes: 34
Posts: 2,172 Likes: 34 |
Looking for Michelin items + NJ oil company related items (Mohawk, Guardian, Whiz, etc) + animal-related petroliana + Gargoyle/Shell/Sinclair items
Posts: 406 Likes: 33
Posts: 406 Likes: 33 |
Very cool! Thank you for posting.
Randy
Here are some inside pictures. The inner top and light manifold were custom built. I will post pictures of them later. A couple reset shafts were welded together so the computer can be reset with the crank. This project was fun and a pain in the a$$ at the same time. If I had an original 71 to look at the inside it would have went a lot smoother. I ended up having to redo some thins because I was winging it as I went.
RandyM |
Posts: 979 Likes: 1
Posts: 979 Likes: 1 |
Looks really good as everything else you do, Matt. Congrats on the job.....Dale
Posts: 1,871 Likes: 48
Posts: 1,871 Likes: 48 |
Posts: 8,513 Likes: 293
Posts: 8,513 Likes: 293 |
Awesome, Matt. Looks like you found a real survivor 71.
Posts: 1,763 Likes: 88
Posts: 1,763 Likes: 88 |
Matt, Another masterpiece, very convincing appearance.
Regards, Jim
Posts: 1,592 Likes: 38
Posts: 1,592 Likes: 38 |
Thank you for the comments. When I finish a rustoration I do not think they look authentic enough for me so it is nice to here others think they have a realistic aged look.
Here are pictures of the inner top. I used both inner tops from the two Wayne 70`s. First the raised square was removed as well as the flange on either side then the second one was cut in half. Next was welding and more cutting.
Posts: 2,313 Likes: 86
Posts: 2,313 Likes: 86 |
Matt, I’m always very impressed with your talents. You did a fantastic job once again . I have been waiting for this post. It looks fantastic!!!
Thanks for sharing with all of us here.
Rob
Posts: 180 Likes: 27
Posts: 180 Likes: 27 |
The outer top was made with two 70 tops as well. The ends were cut off one and the center cut out of the other. A 71 top has more of a curve than a 70 top. I made a cut at the bend of each corner so I could bend the top upward to gain more of a curve. After welding the three pieces together I put the top on the pump before welding the cuts so I could bend the top to match the upper doors as best as possible. Finished the welding and a little body filler and the outer top was done.
The light manifold was a lot of work. I had to get it as short as possible to fit above the sight glass manifold. I cut the bottom off the top socket housing and the top off the main body then welded them together. I added a couple threaded nipples for the display case piping. I cut and threaded some of the original Wayne 70 piping and got the original switch working.
What a very cool project. Looks like you were having fun. Keep the story coming. Greatly appreciate it.
Randy
Posts: 1,165 Likes: 44
Posts: 1,165 Likes: 44 |
What an engineering feat that took a lot of thought ! Great job
The hinge mounts were kept simple. I took some sheet metal strips bent at a 90 degree angle, cut, drilled and screwed them to the frame rails. They were put opposite of the factory hinge mounts so there would be room for the nuts and screws.
The base, where the project started and almost ended. I figured out how long it needed to be and did my cuts on the two cast iron bases I had. I got a surprise when I put the two pieces together. The bases were two different widths. One was 17 inches and the other one was 16 5/8 inches. I almost scrapped the project but decided the see if I could bend it and make it work. I used a couple friction jacks, one to squeeze and the other to spread until the two halves lined up. It was then welded and finished off.
RandyM |
