MATT ALVAREZ #756504 Mon Oct 26 2020 10:52 PM
The light manifold was a lot of work. I had to get it as short as possible to fit above the sight glass manifold. I cut the bottom off the top socket housing and the top off the main body then welded them together. I added a couple threaded nipples for the display case piping. I cut and threaded some of the original Wayne 70 piping and got the original switch working.
MATT ALVAREZ #756505 Mon Oct 26 2020 10:53 PM
2 members like this: buzzy56, buzzy56
MATT ALVAREZ #756512 Tue Oct 27 2020 08:01 AM
What a very cool project. Looks like you were having fun. Keep the story coming. Greatly appreciate it.
Randy
MATT ALVAREZ #756564 Wed Oct 28 2020 07:22 PM
What an engineering feat that took a lot of thought ! Great job
MATT ALVAREZ #756574 Wed Oct 28 2020 09:50 PM
The hinge mounts were kept simple. I took some sheet metal strips bent at a 90 degree angle, cut, drilled and screwed them to the frame rails. They were put opposite of the factory hinge mounts so there would be room for the nuts and screws.
MATT ALVAREZ #756756 Mon Nov 02 2020 09:41 PM
The base, where the project started and almost ended. I figured out how long it needed to be and did my cuts on the two cast iron bases I had. I got a surprise when I put the two pieces together. The bases were two different widths. One was 17 inches and the other one was 16 5/8 inches. I almost scrapped the project but decided the see if I could bend it and make it work. I used a couple friction jacks, one to squeeze and the other to spread until the two halves lined up. It was then welded and finished off.
1 member likes this: RandyM
