#733128
Thu Jul 25 2019 06:37 PM
Posts: 8,513 Likes: 293
Posts: 8,513 Likes: 293 |
Here I am doing the prep work to put up a fluted Revere island light on the far side of my garage. Got the wires trenched in and the retaining wall just about done. Almost ready for concrete in the hole. I'll start painting the pole while the base is curing.
I've only had the pole, harp and shade for over 15 years. About time it comes out of storage and into use.
Posts: 1,165 Likes: 46
Posts: 1,165 Likes: 46 |
Only 15years? How did you decide where to put it that quick?😊. Lookin good. Be sure and post the final installation.
Poured 900 pounds of bag premix concrete in the hole today. Now to clean up and let it cure. Turning my thoughts and efforts on getting the pole looking good.
Posts: 1,165 Likes: 44
Posts: 1,165 Likes: 44 |
We all have projects like that ! 🙂 Called Going to get at em jobs . Glad to see you making headway on it .That concrete is a killer at our age but the results will be well worth it .
Posts: 276 Likes: 1
Posts: 276 Likes: 1 |
Looking good Jim. Lot of hard work.
WANTED:::Barn Hangers...and other fine junk...
Posts: 1,871 Likes: 48
Posts: 1,871 Likes: 48 |
Nice job Jim, hope it was cool for you when mixing that concrete.
Thanks for your comments, guys. This week had cooler temperatures and lower humidity. That made being outside really pleasant. Plus, that spot is in the shade all morning. Feels good to have that part of the project behind me. I bought a Wemo Internet connected dimmer switch on Amazon Prime day for the lamp in the harp.
Posts: 4,293 Likes: 27
Posts: 4,293 Likes: 27 |
The Revere pole's access cover was mangled. I have it straightened out pretty well. Thought that would be the hard part. Turned out that a pipe plug that was put in the top was tough to get out. Tried everything and wound up cutting it out in pieces with a hack saw. Paint is stripped. Ready soon to sand and prime.
Fun, fun, fun, in the summertime.
As you can see, the Revere Island Lampost is bolted down and is now operational. The light under the shade is remote dimmable, controlled by a Wemo app on my phone. The spotlights on top are motion activated.
Posts: 1,765 Likes: 90
Posts: 1,765 Likes: 90 |
Jim, Nice job. That looks great!
Regards, Jim
Here's a photo tonight with the Revere pole light on the dimmed setting after dark. I can control the lamp on/off and dimming from my phone.
Posts: 297 Likes: 7
Posts: 297 Likes: 7 |
Man nothing like a revere lite at night, way to go Jim.
Posts: 4,880 Likes: 50
Posts: 4,880 Likes: 50 |
Posts: 873 Likes: 25
Posts: 873 Likes: 25 |
What equipment is required to wire in to use that WEMO app on your phone to control the light?
What equipment is required to wire in to use that WEMO app on your phone to control the light? It sounds complicated, but really isn't. The keys to making an Internet connected switch work, are to have a good WiFi signal at the switch location and having a neutral wire available in the switch electrical box. Basically, you just replace a regular switch with a WEMO or similar Internet connected switch. I used a WEMO Dimmer switch I got from Amazon. Pictured below. You can lightly stroke your finger along the row of dots on the switch face to control the dimmer level and tap the switch for on/off. From the WEMO smartphone app, you can also do those things as well as set schedules. Mine runs dusk to dawn (auto adjusted to correct time each day) at 1% dimmer power. I can make it brighter from my phone when I expect visitors. The switch needs the black line and load wires, a ground wire and the white neutral wire to make its own little circuit to power the WiFi. If you don't have all those wires in your switch box, it just won't work out. I ran two circuits out to the pole so one could control the light inside the porcelain shade and the other to separately power the motion spot lights on top. 12/3 w/ground Use a WiFi device at the proposed switch location to see if you have a strong enough signal to be dependable at that spot. I didn't have a strong signal there 130' from the house, so I bought a new "mesh" router system that included 3 access points. That system gives us good WiFi all over the house, 2 garages, patio and the yard. The switch setup is done through the app and usually goes well. WEMO's support site is pretty good. I couldn't find the dusk/dawn thing until I read the support page for schedules. If you get stuck, send me a private message or email and I'll try to help. I did not trench in pipes to feed the water and air connections since I already have them at the garage. I do like the look they give the pole.
WEMO DImmer Switch
Water and air connectors on the Revere pole.
Posts: 838 Likes: 11
Posts: 838 Likes: 11 |
Posts: 2,995 Likes: 110
Posts: 2,995 Likes: 110 |
Looks great Jim. I think they were originally controlled with iPhones in the 1950’s also 😂😂😂
Thanks for all your kind comments. I rooted through my junk and found a short length of old red air hose to put on my Revere pole. Somewhere I have an old style long tire chuck to put on the hose. I might start looking in garage sales for a length of vintage patina rubber water hose for the other side.
Rubber air hose on Revere pole
Thanks for all the detail on the WEMO wiring. j
Posts: 15,631 Likes: 455
Posts: 15,631 Likes: 455 |
Nice Revere light Jim. Looks great lit up.
Posts: 4,962 Likes: 17
Posts: 4,962 Likes: 17 |
Posts: 2,085 Likes: 11
Posts: 2,085 Likes: 11 |
I have been watching your progress, looks great! Also remember those great mornings you started! Sure miss them!
