Gilbarco 996 "Rustoration" #719941
Wed Nov 21 2018 02:23 PM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
Bought this 996 as is, for $650. Bones are great, no rot. Everything was there minus the glass & ID Plate (I need one if u have it)
Plans:
- Switch to Blue Sunoco
- Panels leave as is but spray a 2-part clear epoxy (Eastwood's Areospace 2k) to make it pop.
- New Gaskets, Rubber, Glass, Chrome Trims on order.
- Frame & base painted matte or flat black.
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #719957
Wed Nov 21 2018 09:03 PM
Reedsburg,Wi,USA
Jhaas63 Online content
Jhaas63  Online Content
Reedsburg,Wi,USA
Awesome. I would leave her as a Mobil but they are my favorite so that doesn’t really count. Post “after” photos. Very neat project!
Re: Gilbarco 996 "Rustoration" [Re: Jhaas63] #719962
Thu Nov 22 2018 07:22 AM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
I'll post pics as I work on it. Waiting for parts right now....My wifes Grandfather owned a Sunoco station years ago. Kind of a memories thing for her...
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #720039
Fri Nov 23 2018 06:41 PM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
Just got the 1st set of parts....QUESTION - How does the ad glass rubber go on? Corners look weird. How does it attach to the panel? Said to order "rb 101" rubber for the ad glass so that's what I got.
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #720050
Fri Nov 23 2018 10:39 PM
Locust, NC
57-Chevy Online content
57-Chevy  Online Content
Locust, NC
It should have been this style rubber for 900 series ad glass. The inside corners of rubber will need to be cut out. The glass corner will be exposed and not in the little track, if that makes sense?
KJV Psalms 16:11
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #720051
Sat Nov 24 2018 05:02 AM
Bunker Hill, WV,USA
1
1PetroFan Offline
1PetroFan  Offline
Bunker Hill, WV,USA
I think the last 966 I owned had raised holes for the CONTAINS LEAD sign. If yours has the factory stamped raised holes, your longer CONTAINS LEAD sign is too long to use the factory stamped holes.
Re: Gilbarco 996 "Rustoration" [Re: 57-Chevy] #720053
Sat Nov 24 2018 07:04 AM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
In the process of figuring out the wrong rubber situation w/ Don from Vics
Re: Gilbarco 996 "Rustoration" [Re: 1PetroFan] #720058
Sat Nov 24 2018 08:23 AM
Locust, NC
Locust, NC
Brady is right, I've had probably 50 or more of these 900 series Gilbarco pumps over the years. I've never seen one with the long lead signs. Those are for older pumps. You need the smaller plates.
KJV Psalms 16:11
Re: Gilbarco 996 "Rustoration" [Re: 57-Chevy] #720061
Sat Nov 24 2018 08:35 AM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
Jeez, I'm batting a 1000 today Haha. New to this. I ordered the correct ad glass rubber this morning, so that's done
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #720118
Sun Nov 25 2018 06:58 AM
Bunker Hill, WV,USA
1
1PetroFan Offline
1PetroFan  Offline
Bunker Hill, WV,USA
Where else are you going to have so much fun??? I still can't get that style rubber in a pump. Lucky for me I have a great friend that lives a half mile from me that is good at it.
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #720152
Sun Nov 25 2018 04:17 PM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
Made the only progress I could until more parts show up next week...
- Frame was scrubbed down w/ Krud Kutter Rust Remover & sprayed w/ Undercoating to seal her up.
- Sandblasted Sight Glass pieces & Nozzle Holder thinger. Sent the Sight glass through the dishwasher.
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #720294
Tue Nov 27 2018 05:20 PM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
Finished wet sanding & cleaning w/ Simple Green. They came out nice, lots of overspray & rust came off.... Ready for Blue paint around the window (where the red is) tomorrow.
What goes in the hole in the 2nd pic? I need to get whatever it is...
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #720303
Tue Nov 27 2018 07:06 PM
Locust, NC
Locust, NC
Rubber grommet for light switch. The only place I see that has them is Past Gas in FL.
KJV Psalms 16:11
Re: Gilbarco 996 "Rustoration" [Re: 57-Chevy] #720304
Tue Nov 27 2018 07:10 PM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
Thank you! I dont have or want the globe so I guess I'll just get the grommet.
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #720565
Sun Dec 02 2018 11:18 AM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
Clear coated all panels w/ 2 part epoxy from Eastwood. Installed new sight glass rubber & chrome trims. Found a Serial # plate thanks to Tom Buckles.
Still waiting on the 2 door rubbers & Lead signs. Waiting to do the Ad & window glass last...
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #721154
Tue Dec 11 2018 07:15 PM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
Getting really close to done.
Still needs both door moldings & face glass. Also waiting on both "Contains Lead" signs
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #721254
Thu Dec 13 2018 01:45 PM
Bunker Hill, WV,USA
1
1PetroFan Offline
1PetroFan  Offline
Bunker Hill, WV,USA
I see the face plate is for the double dispenser model. You might like the look of the face plate for the single dispenser a bit better. They have a curved edge on both sides and bottom to make a nice clean look. Great looking pump!
Re: Gilbarco 996 "Rustoration" [Re: 1PetroFan] #721257
Thu Dec 13 2018 02:55 PM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
You know I thought it looked a bit weird. I'll look into the correct ones
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #721355
Fri Dec 14 2018 09:01 PM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
All done & in it's new home...
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #721356
Fri Dec 14 2018 09:03 PM
PA
JSTOR Offline OP
JSTOR  Offline OP
PA
BEFORE
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #723390
Sun Jan 20 2019 11:15 AM
Louisiana
E
Ed48 Offline
Ed48  Offline
E
Louisiana
Nice pump! I’m not an experienced collector but I have a Gilbarco that I think is a 996 and its ad glass opening is slightly larger than then the meter opening. Yours appears to be the same sized openings...perhaps a 906 I need a panel but I’m confused between a 906 and 996. How were you able to identify your pump as a 996?
Re: Gilbarco 996 "Rustoration" [Re: JSTOR] #723398
Sun Jan 20 2019 12:29 PM
Cameron Park,Ca.
MATT ALVAREZ Online content
MATT ALVAREZ  Online Content
Cameron Park,Ca.
The 996 has horizontal molding trim (some have one piece and some have two on each door) and the 906 has a "V" trim around the sight glass. There are other differences but that is the easiest way to tell them apart.
Page Time: 0.036s Queries: 24 (0.010s) Memory: 1.9615 MB (Peak: 2.1581 MB) Zlib disabled. Server Time: 2019-03-22 02:32:33 UTC
