A38 Rusto from rust #717645
Sat Oct 06 2018 11:49 AM
Michigan, Union Pier
Done4 Offline OP
Done4  Offline OP
It's raining like heck today stuck in the shop and I figured I'd burn some time posting my progress on an A38 I've been working on. This one has been really slow and still has a ways to go but I figured I's share whats done.
It all started with these lens I've had a long time and figured it was time to use them. My tape measure is pretty long. They are not in minty condition so I figured rather then a restoration I would do the as found route to make the lens look correct. I had this pump as a parts pump and had lead a pretty rough life. Sides were bad on the bottom and one door was missing about 6"s on the bottom. I looked at it and said "what the heck, let's give it a go". I talked to my fabricator guy and he wanted no part of it. So I made a mold for the bottoms of the side and glassed them. Same with the door. Usual stuff, lots of sanding, filling, fitting.
I also had a station lighter on one of my other pumps that I decided I would use on this because the off white was close. So I cleaned it up and it's close but still have a little blending to make it right, not much though.
Cleaned and sealed the frame, pump and got the electrical rewired. With that completed I started to fit the sheet metal. Going for the look I want I left some of the dents and sealed the flake. I'm at a stop on the pump right now because I'm missing a part (can't find the damn thing). Called Tom and it's on it's way. Thanks Tom.
Getting a pump plate is above my pay grade so I made a water slide decal which I will use. I have the artwork completed and wanted to see if the size looked correct so I photoshopped it in. I think it will work.
Well, that's about it for now and I will post the pump when it's done. Thanks for looking and I would appreciate any info on the lens because so far I can't find anything on them.
1a_lens.JPG1b_found pump.jpg1c_bottom rust through.jpg1d_phillips station lighter.jpg
Re: A38 Rusto from rust [Re: Done4] #717646
Sat Oct 06 2018 11:51 AM
Done4 Offline OP
Done4  Offline OP
More of the progress.
1e_side panel.jpg1ee_inside side panels.JPGbranded pump.jpgbranded tower.jpg
Re: A38 Rusto from rust [Re: Done4] #717657
Sat Oct 06 2018 02:25 PM
Peotone Illinois U.S.A
Bass Master Offline
Bass Master  Offline
Les,
Looks awesome so far, looking forward to seeing it done!!
Brian
Re: A38 Rusto from rust [Re: Done4] #717663
Sat Oct 06 2018 03:16 PM
Ohio
Y
Yellow57 Online content
Yellow57  Online Content
Y
Ohio
Love it !! Shiny pumps were on the island one day looking new , what your doing is awesome, what I’ve done to my22 pumps!!
Re: A38 Rusto from rust [Re: Done4] #717669
Sat Oct 06 2018 07:45 PM
Missouri,USA
Rabbitman Online content
Rabbitman  Online Content
Missouri,USA
Looks good Les. Sometimes you just gotta make stuff work...
Re: A38 Rusto from rust [Re: Done4] #717673
Sat Oct 06 2018 09:19 PM
Cameron Park,Ca.
MATT ALVAREZ Online content
MATT ALVAREZ  Online Content
Cameron Park,Ca.
It looks really good!!! It is fun saving a pump other people would part out.
Re: A38 Rusto from rust [Re: Done4] #717729
Sun Oct 07 2018 09:19 PM
Hays, Kansas
bsplichal95 Online content
bsplichal95  Online Content
Hays, Kansas
I love it!! Great job! I like to see others saving pumps that others would part out. I try to do the same!
Re: A38 Rusto from rust [Re: Done4] #717743
Mon Oct 08 2018 02:25 AM
MICHIGAN
Steven C. Offline
Steven C.  Offline
MICHIGAN
Wow Les!! Incredible work as always!! I can't imagine the hours you have into that!! Love the whole rusto theme thing! And what an incredible pump with the station lighter. Absolutely love it!!
Re: A38 Rusto from rust [Re: Done4] #717765
Mon Oct 08 2018 09:19 AM
Done4 Offline OP
Done4  Offline OP
Thank you guys. I just ordered the water side paper which is the last piece of the puzzle. Hope to have this fella done in the coming weeks. It will be interesting to see if I can make the decals look correct. Next challenge.
Yes Steve, lots of messing around but it's nice to see this guy come back to life.
Re: A38 Rusto from rust [Re: Done4] #718038
Sun Oct 14 2018 10:43 AM
Done4 Offline OP
Done4  Offline OP
Small update, finally got the tower color more in line with the pump color. The pic on the left is the tower just cleaned up, it was too white. I thought this would be a no brainer but it took more time then I initially thought, as usual. Now it's take it a part for final assembly. Got the missing part thanks to Tom. I hope the last post will be the finished pump. Fingers crossed.
Re: A38 Rusto from rust [Re: Done4] #718975
Thu Nov 01 2018 12:56 PM
Done4 Offline OP
Done4  Offline OP
More progress, got the water slide decal paper and made the transfer. This stuff works really well, I was surprised. I have to wait a day then go back and bugger them up a little bit. I also have some NOS white hoses and decided for now to use one on the 38.
Re: A38 Rusto from rust [Re: Done4] #719099
Sat Nov 03 2018 08:39 PM
Cameron Park,Ca.
Cameron Park,Ca.
I really like how this pump is coming along. Too bad that new hose did not have brass ends. If it did you could dip them in brass ager to make it look old. I did this to a tan cloth hose. I also got the cloth dirty and ground the dirt in with some window cleaner on my hands, then lightly sanded it with 80 grit sand paper to make it a little fuzzy for the used look.
Re: A38 Rusto from rust [Re: Done4] #719103
Sat Nov 03 2018 09:17 PM
Phelan, Ca
MtGoat Offline
MtGoat  Offline
Phelan, Ca
Looks Great !!!
Re: A38 Rusto from rust [Re: Done4] #719117
Sun Nov 04 2018 09:41 AM
Done4 Offline OP
Done4  Offline OP
Matt, I was thinking I might try painting them a brass color then aging the paint. I agree the shiny chrome does not work with the pump but we will try to fix that. I did a pump about 15 years ago that is in my collection and use one of these hoses and over the years it has yellowed which I like. But on this one I don't want to wait 15 years. Attached is a pic of the hose.
Re: A38 Rusto from rust [Re: Done4] #719133
Sun Nov 04 2018 02:39 PM
Cameron Park,Ca.
Cameron Park,Ca.
The hose on the Pure pump would look better on the A-38, you should consider swapping them.
