White Crown. #714359
Sat Aug 04 2018 11:37 AM
citrus heights ca.95610
hawkike Offline OP
hawkike  Offline OP
Here you go!
Frank Jordan
Re: White Crown. [Re: hawkike] #714368
Sat Aug 04 2018 03:36 PM
MN United States
Tankar Offline
Tankar  Offline
MN United States
yep junk. they never used grommets
Re: White Crown. [Re: Tankar] #714372
Sat Aug 04 2018 04:51 PM
Ontario, Canada
TexasRanger84 Offline
Ontario, Canada
There are no grommets on that sign just wear where the screws or attachment to the pump would have been.
Re: White Crown. [Re: hawkike] #714373
Sat Aug 04 2018 04:53 PM
Ontario, Canada
Ontario, Canada
Hawkike, great photo! Looks identical to mine! Good to know. Thank you so much for the photo and the help. Would you also happen to have a photo of the back?
I really appreciate your help and time.
Re: White Crown. [Re: hawkike] #714375
Sat Aug 04 2018 05:02 PM
MN United States
Tankar Offline
Tankar  Offline
MN United States
geeeez I better get stronger glasses I swear I seen grommets
Re: White Crown. [Re: hawkike] #714377
Sat Aug 04 2018 06:22 PM
California
W
wayno48 Offline
wayno48  Offline
W
California
It looks like it should have had grommets to keep the fasteners off the porcelain
Re: White Crown. [Re: TexasRanger84] #714396
Sat Aug 04 2018 11:00 PM
hawkike Offline OP
hawkike  Offline OP
I will post one on Sunday.
Frank Jordan
Re: White Crown. [Re: hawkike] #714412
Sun Aug 05 2018 12:08 PM
Ontario, Canada
Ontario, Canada
Thank you!
Re: White Crown. [Re: hawkike] #714425
Sun Aug 05 2018 03:03 PM
hawkike Offline OP
hawkike  Offline OP
The back,just as found 40 years ago.
Tankar--were you referring to this sign when you said "junk"? Just wondered as it is an original and no doubt it had grommets originally.
Thanks!
Frank Jordan
Re: White Crown. [Re: hawkike] #714440
Sun Aug 05 2018 06:10 PM
MN United States
Tankar Offline
Tankar  Offline
MN United States
I thought I seen grommets and standard never used them on there pump plates. just bad eye sight.
Re: White Crown. [Re: Tankar] #714443
Sun Aug 05 2018 06:30 PM
hawkike Offline OP
hawkike  Offline OP
Thanks.
Frank Jordan
Re: White Crown. [Re: hawkike] #714446
Sun Aug 05 2018 07:08 PM
Hillsdale, Michigan
DWSheffer Offline
DWSheffer  Offline
Hillsdale, Michigan
Always looking for Mobil items I don't already have!
Re: White Crown. [Re: DWSheffer] #714461
Sun Aug 05 2018 08:33 PM
hawkike Offline OP
hawkike  Offline OP
I did not know the originals did not have grommets,only one that I have had and just assumed they did.
Thanks!
Frank Jordan
Re: White Crown. [Re: hawkike] #714468
Sun Aug 05 2018 09:05 PM
Ontario, Canada
Ontario, Canada
Thanks!
Hawkike,
Thank you! The back of mine is the same as yours minus the red paint. The back of mine doesn't have any rack marks (the straight narrow lines you see across the backs of a lot of porceline signs) I was worried that may indicate it is a repro. However, again mine is identical to yours front and back (just a different batch number/IR year and without the red paint on the back).
Re: White Crown. [Re: DWSheffer] #714470
Sun Aug 05 2018 09:09 PM
Ontario, Canada
Ontario, Canada
Originally Posted by DWSheffer
Hi Darin,
Thanks for the input. I got reading ypur posts about the repro Mobil pump plates earlier today and what to watchout for. That knowledge so valuable to younger guys like me getting in the hobby. It's hard when all this stuff was already antique and well out of service before I was even born. Helpful guys like you definitely make "doing our homework" a bit easier.
Thank you.
Dallas,
Moderated by  Oldgas, Ryan Underthun, Watchdog5
Page Time: 0.027s Queries: 16 (0.006s) Memory: 1.9176 MB (Peak: 2.0601 MB) Zlib disabled. Server Time: 2019-02-20 13:10:38 UTC
