#710279
Sat May 26 2018 07:21 PM
Posts: 211 Likes: 36
Posts: 211 Likes: 36 |
I took a drive out to Regina, Saskatchewan today and came home with two Gilbarco 96Cs. Nine hours of driving was well worth it. They are complete and the sight glasses are intact. There are a few dings on the door edges but nothing beyond repair. The green one appears to have a decal underneath that looks to me like a Imperial oil decal. What do you guys think?
Posts: 2,195 Likes: 74
Posts: 2,195 Likes: 74 |
I picked them up from a fella named Joe, he had traded a restored visible pump for two Wayne 70’s and these two Gilbarcos that i picked up.. I was too late on the 70’s they went fast!
I’ve been wasting no time since I got back. I’ve got one stripped down and have taken a inventory of parts that I’ll be needing.
Posts: 4,293 Likes: 27
Posts: 4,293 Likes: 27 |
Time to get some work done this weekend, abrasive blast on the bases and frames with steel grit and then switching out to glass bead for the doors and side panels on both pumps. I degreased the sight glasses and am always impressed at how clean they come out with a bit of scrubbing.
Posts: 1,064 Likes: 2
Posts: 1,064 Likes: 2 |
With my experience, the G & B 96's were one of the easiest pumps to restore, and look great when finished. Yours will too!
Thanks I’ll get some more pictures put up tonight!
The door skins were difficult to blast as there was three coats of existing paint on them. The doors are a thin gauge of metal and had to be blasted at a distance so that they wouldn’t warp. I stacked the doors on top of each other to help them hold their shape while I was blasting. It took a afternoon of careful work to remove the paint from the panels and components on both pumps. Next up will be hammering out the dents.
I am so jealous of your work area. Looking good-keep us posted.
The door panels have taken a little longer to get worked out due to some difficult creased dents at the edges. Here is a before and after of one of these dents I had to give a little heat to. On the upside I’ve got both bases and frames powder coated!
I’m back from vacation and stopped in at Jim’s Garage in New Westminster to pick up some reproduction parts for the Gilbarcos. I’ve mostly been working at getting the small detail work done and today used a chrome powder coat to refurbish the shroud around the veeder root computers.
The veeder root on the left has a original polished aluminum shroud around the bottom. The top half is coated chrome. The veeder root on the right has the entire shroud coated chrome.
Posts: 2,995 Likes: 109
Posts: 2,995 Likes: 109 |
Thanks! It’s almost a shame that they’ll be hidden behind the faceplates haha
Now that I’m finished hammering out the dents I test fit my panels and doors on both pumps. I attached the door hooks and marked each position on each door individually once I had a good fit against the pump. Soon these panels will be ready for coating. Once coated I can re attach the door hooks in same locations on each door for the same fit as when I mocked it up.
I spent today at the shop and made some good progress on the pumps. I finished powder coating the panels on both pumps and had a friend in to help with re wiring the electrical. One of the original pull switches was rusted solid so a simple toggle switch was spliced in. I’m waiting on one more shipment for the chrome door trim and then I should have these pumps buttoned up.
Posts: 8 |
I finished the two Gilbarco pumps this weekend. I went with Texaco Fire Chief and Sky Chief. I decided against a solid red and solid silver pump and went with a two tone look instead. I ran into a couple issues when putting them back together one was using a weldbond glue on the rubber door gasket that didn’t bond anything! I cleaned off each door and used a Gorilla super glue instead. It dried in 20 seconds and was solid. The only other issue was the the shaft on reset handle is a bit too short on each pump to make it to the Veeder Root. I’ll be making up a couple new ones so that it is functioning. Hope everyone enjoyed following the progress on these pumps as much as I did working on them!
Posts: 93 |
The computers look amazing. I also order many of my parts from Jim. Great guy to deal with and really knows his stuff.
Posts: 5,980 Likes: 24
Posts: 5,980 Likes: 24 |
Looking good, always a good combination with those 40's -50's pumps.
