Re: Two Gilbarco 96C’s [Re: AlbertaNorthStar] #712823
Sun Jul 08 2018 08:23 PM
Medicine Hat, Alberta, Canada
AlbertaNorthStar Offline OP
Now that I’m finished hammering out the dents I test fit my panels and doors on both pumps. I attached the door hooks and marked each position on each door individually once I had a good fit against the pump. Soon these panels will be ready for coating. Once coated I can re attach the door hooks in same locations on each door for the same fit as when I mocked it up.
528349B4-AD1D-48F8-9DEE-F18B2671A249.jpegE4417B0A-86B2-44D9-8DC5-B97C0DB4EB2C.jpegE86A79DB-B9B6-4988-ADCC-0A953383C850.jpeg
Re: Two Gilbarco 96C’s [Re: AlbertaNorthStar] #713258
Sun Jul 15 2018 10:00 PM
I spent today at the shop and made some good progress on the pumps. I finished powder coating the panels on both pumps and had a friend in to help with re wiring the electrical. One of the original pull switches was rusted solid so a simple toggle switch was spliced in. I’m waiting on one more shipment for the chrome door trim and then I should have these pumps buttoned up.
A06DE900-B507-4551-98A8-A40C16C8F21E.jpeg1CFA1B6A-C667-4BE9-84DD-84BC88CEAD70.jpegD10868F5-9530-4842-9739-7E24A2DE55CE.jpeg
Re: Two Gilbarco 96C’s [Re: AlbertaNorthStar] #713311
Mon Jul 16 2018 08:49 PM
South Dakota
CountryRoad Offline
CountryRoad  Offline
South Dakota
Looks great!
Re: Two Gilbarco 96C’s [Re: AlbertaNorthStar] #713685
Sun Jul 22 2018 07:15 PM
I finished the two Gilbarco pumps this weekend. I went with Texaco Fire Chief and Sky Chief. I decided against a solid red and solid silver pump and went with a two tone look instead. I ran into a couple issues when putting them back together one was using a weldbond glue on the rubber door gasket that didn’t bond anything! I cleaned off each door and used a Gorilla super glue instead. It dried in 20 seconds and was solid. The only other issue was the the shaft on reset handle is a bit too short on each pump to make it to the Veeder Root. I’ll be making up a couple new ones so that it is functioning. Hope everyone enjoyed following the progress on these pumps as much as I did working on them!
Re: Two Gilbarco 96C’s [Re: AlbertaNorthStar] #716307
Sat Sep 08 2018 07:43 PM
Niagara Falls Ontario Canada
kevinz Offline
kevinz  Offline
The computers look amazing. I also order many of my parts from Jim. Great guy to deal with and really knows his stuff.
Re: Two Gilbarco 96C’s [Re: AlbertaNorthStar] #716321
Sun Sep 09 2018 08:10 AM
Portland Oregon
Craig Osbeck Offline
Portland Oregon
Looking good, always a good combination with those 40's -50's pumps.
Page Time: 0.026s Queries: 17 (0.011s) Memory: 1.8720 MB (Peak: 1.9728 MB) Zlib disabled. Server Time: 2019-01-19 16:19:12 UTC
