#709403
Wed May 09 2018 08:31 PM
Posts: 707 Likes: 17
Posts: 707 Likes: 17 |
I purchased this Wayne 615 recently. There is a small bracket on the side that appears to be original with the skins. It was a farm pump. Does anyone have any idea what the purpose or use this little bracket had? Thanks, Steve
Posts: 1,682 Likes: 17
Posts: 1,682 Likes: 17 |
Nozzle rest. Looks like yours is missing the drain back for some reason.
Posts: 1,655 Likes: 24
Posts: 1,655 Likes: 24 |
Was the drain back attached to this piece? Does anyone have a photo of a complete piece so I can see what I am missing? Thanks
Posts: 2,457 Likes: 24
Posts: 2,457 Likes: 24 |
The drain back is a pipe attached to the inner drain plumbing and extending out side the pump through the skins. It does not attach to the nozzle rest. The nozzle was placed into the drain back at days end to remove any left over product from the cylinder. Then it was pad locked to the rest to prevent theft. Paul www.severngaspumps.com
Posts: 316 |
Here are a couple of pictures of the drain back pipe
Thanks guys for the information and photos of the drain back pipe. This is a huge help! Thanks again! Steve
Posts: 1,747 Likes: 42
Posts: 1,747 Likes: 42 |
It's probably been "gutted" like mine. I don't see the pump handle either. There is a rod, welded in mine, to hold the handle in one spot. Second pic is of the inside.
If there is no hole in the skins that may explain why they don’t match the paint on the rest of the pump. Repop skins? Chris
There is a hole in the skins just below the bracket. Also the pump is intac inside, is loose and has a handle.
One last question...I see you can buy a reproduction drain back for a Wayne 615 at Gas Pump Heaven. Do you simply build the rest of the piece yourself with threaded pipe and an elbow?
Yes, very simple, as you stated. Paul www.severngaspumps.com
Posts: 7 |
Keep us posted on progress. I'm also in the process of restoring my 615 and I don't have the drain back either so this was helpful.
I probably have some drain back parts if anyone is interested? I know I have all the piping and I think I have another complete setup too?
KW, I would be interested. Please let me know what you have and if the would fit a Wayne 615. Thanks, Steve
I will try to take a look tomorrow and get back to you.
Kevin F. sold me an original drainback for my Wayne 615. I just installed it. I had to take the skins off and use a propane torch to heat the plug in order to remove it from the pump. I have posted a pic. Thanks guys...now it cannot be said that my Wayne 615 visible is “drainbackless”. Steve
