Welded metal piece on Wayne 615 #709403
Wed May 09 2018 08:31 PM
Central Texas
Stephenwarren30 Offline OP
Central Texas
I purchased this Wayne 615 recently. There is a small bracket on the side that appears to be original with the skins. It was a farm pump. Does anyone have any idea what the purpose or use this little bracket had?
Thanks,
Steve
681BA1EC-AE6C-433E-9EDA-4C1B4C9075A1.jpeg6494AA0F-4CCC-4A2D-BB3B-FF6BABF7C459.jpeg6F9A408E-A3F2-4F0F-993D-3DB3A6BB3573.jpeg353F53F7-C345-471F-B394-44B3E0C82E4B.jpeg
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709405
Wed May 09 2018 10:40 PM
Oregon
petropumps Offline
petropumps  Offline
Oregon
Nozzle rest. Looks like yours is missing the drain back for some reason.
Re: Welded metal piece on Wayne 615 [Re: petropumps] #709409
Thu May 10 2018 03:22 AM
northern in.
cggas Offline
cggas  Offline
northern in.
Yep, nozzle rest. Chris
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709410
Thu May 10 2018 05:25 AM
Central Texas
Central Texas
Was the drain back attached to this piece? Does anyone have a photo of a complete piece so I can see what I am missing?
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709412
Thu May 10 2018 06:25 AM
Severn, Maryland USA
gasmansgp Offline
gasmansgp  Offline
The drain back is a pipe attached to the inner drain plumbing and extending out side the pump through the skins. It does not attach to the nozzle rest. The nozzle was placed into the drain back at days end to remove any left over product from the cylinder. Then it was pad locked to the rest to prevent theft. Paul www.severngaspumps.com
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709418
Thu May 10 2018 08:16 AM
Allyn, Wa
42packard Offline
42packard  Offline
Allyn, Wa
Here are a couple of pictures of the drain back pipe
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709420
Thu May 10 2018 09:03 AM
Central Texas
Central Texas
Thanks guys for the information and photos of the drain back pipe. This is a huge help!
Thanks again!
Steve
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709428
Thu May 10 2018 12:39 PM
www.mancaveshoppe.com email:bi...
Man-Cave-Shoppe Dave Offline
It's probably been "gutted" like mine. I don't see the pump handle either. There is a rod, welded in mine, to hold the handle in one spot. Second pic is of the inside.
Dave(509)847-5893 LOOKING-4:WELDING SIGNS,Charter/Finance/PulOil/Trulite/TruTest-Oil,FREEDOM cans,True's gas CORALINE/RAINBOW,FLYING A,Wa/Or/Id Chief!
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709431
Thu May 10 2018 01:58 PM
northern in.
cggas Offline
cggas  Offline
northern in.
If there is no hole in the skins that may explain why they don’t match the paint on the rest of the pump. Repop skins? Chris
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709464
Fri May 11 2018 06:28 AM
Central Texas
Central Texas
There is a hole in the skins just below the bracket. Also the pump is intac inside, is loose and has a handle.
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709492
Sat May 12 2018 05:11 AM
Central Texas
Central Texas
One last question...I see you can buy a reproduction drain back for a Wayne 615 at Gas Pump Heaven. Do you simply build the rest of the piece yourself with threaded pipe and an elbow?
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709493
Sat May 12 2018 06:19 AM
gasmansgp Offline
gasmansgp  Offline
Yes, very simple, as you stated. Paul www.severngaspumps.com
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709503
Sat May 12 2018 02:23 PM
Central Texas
Central Texas
Thanks gasman!
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709734
Tue May 15 2018 07:42 PM
Ankeny, Iowa
Maj Offline
Maj  Offline
Ankeny, Iowa
Keep us posted on progress. I'm also in the process of restoring my 615 and I don't have the drain back either so this was helpful.
Re: Welded metal piece on Wayne 615 [Re: Stephenwarren30] #709736
Tue May 15 2018 07:54 PM
Devils Lake, ND---USA
K W FRITH Offline
K W FRITH  Offline
I probably have some drain back parts if anyone is interested? I know I have all the piping and I think I have another complete setup too?
Page Time: 0.054s Queries: 18 (0.017s) Memory: 1.9212 MB (Peak: 2.0718 MB) Zlib disabled. Server Time: 2019-01-18 12:30:20 UTC
