Hanging Signs in a Pole Building #701870
Fri Jan 05 2018 08:43 AM
Peoria, IL
BryceG Offline OP
BryceG  Offline OP
Peoria, IL
I am finishing up building a new pole building and will probably start hanging up some signs later this spring.
Wondering if anyone has any experience with hanging signs from the trusses of a pole building? I am concerned with the potential weight load on the bottom of the trusses.
Anyone have experiences or thoughts to share?
Follow Me & my Finds on Instagram: @bryce_gillespie
Re: Hanging Signs in a Pole Building [Re: BryceG] #701873
Fri Jan 05 2018 09:00 AM
Midland, Michigan
BrianH Offline
BrianH  Offline
Midland, Michigan
Bryce,
I have been hanging signs from the trusses on my barn using heavy eye bolts screwed into the bottom of the truss. I have no real concerns but then again I don't have a lot of big signs (yet). If you think you have too much weight on your trusses, I would be happy to stop by and relieve you of several of your signs so that you don't have to stay awake at night worrying about it. wink
BrianH
Re: Hanging Signs in a Pole Building [Re: BryceG] #701874
Fri Jan 05 2018 09:27 AM
MICHIGAN
Steven C. Offline
Steven C.  Offline
MICHIGAN
I'm not a structural engineer, but I would think if your trusses aren't safety factored higher than the weight of a few signs, you better hope you don't get a big wet snow.
Re: Hanging Signs in a Pole Building [Re: BryceG] #701876
Fri Jan 05 2018 09:45 AM
Peoria, IL
BryceG Offline OP
BryceG  Offline OP
Peoria, IL
Steve... that was my thought as well. But after reading, it seems the bottom cord of a truss isn't usually designed for much additional weight.
Cause snow weight would be on the roof & distributed to the posts, not necessarily putting much strain on the bottom of the truss
Re: Hanging Signs in a Pole Building [Re: BryceG] #701880
Fri Jan 05 2018 09:59 AM
Michigan, Union Pier
Done4 Offline
Done4  Offline
I have had signs hanging from my truss's for 20 years and so far no problems. And we get mucho snow around here, so the snow loads they must support are factored into my truss's. But I have often wondered if I was creating a problem?
Re: Hanging Signs in a Pole Building [Re: BryceG] #701882
Fri Jan 05 2018 10:04 AM
Ontario,Can
junior25 Offline
junior25  Offline
Ontario,Can
I've never had a problem using the screw in eye bolts for signs that are 48" or smaller. For bigger heavier or neon signs I lay a piece of 2"x 2" square tubing in the attic across 3 trusses and loop the chain around the tubing. Although this requires drilling a hole in the ceiling to fit the chain through.
Daryl
Re: Hanging Signs in a Pole Building [Re: junior25] #701892
Fri Jan 05 2018 11:54 AM
Cleveland,Ohio U.S.A.
JimT Offline
JimT  Offline
Bryce -check with the manufacturer if your really worried. Honestly Im thinking there should be no problem.Are you going to hang drywall as well? If you get the ones with the walls built in (Queen Truss??) then you have floor/ceiling joists, plenty of strength and a storage area. Worth the extra$$ IMO. Those are the type I would like to use if I ever get my building built.
Re: Hanging Signs in a Pole Building [Re: BryceG] #701894
Fri Jan 05 2018 12:09 PM
Peoria, IL
BryceG Offline OP
BryceG  Offline OP
Peoria, IL
the trusses are just the standard pole barn truss on 8ft centers. not sure who the manufacturer as the trusses were already up on the building when i bought it... it was an previously an open-sided hay barn that was built about 10 years ago, and I'm just closing it in and finishing it. you can kinda see the trusses in this picture...
Re: Hanging Signs in a Pole Building [Re: BryceG] #701895
Fri Jan 05 2018 12:21 PM
Midland, Michigan
BrianH Offline
BrianH  Offline
Midland, Michigan
Bryce,
I would think for metal porcelain signs, you really shouldn't have a problem. My 48" Shell is the biggest, heaviest sign I have and I be it's only 50 pounds or so. So even if you hung six of those across the same truss, that's only 300 pounds. Plus, the ones near the walls won't put as much strain on the truss since some of that weight would be transferred to the poles I would think. Now, if you had some large neon signs, I would be careful not to put those on the same truss and would span them across to distribute the weight better.
I see you didn't take me up on my offer Bryce...
BrianH
Re: Hanging Signs in a Pole Building [Re: BryceG] #701896
Fri Jan 05 2018 12:25 PM
Peoria, IL
BryceG Offline OP
BryceG  Offline OP
Peoria, IL
thanks for the opinion Brian... it helps. thats what im looking for, people with experience or stories of failures so that i dont experience the same, ha!
ill take you up on your offer, but at this point you have to buy the building too! smile
Re: Hanging Signs in a Pole Building [Re: BryceG] #701897
Fri Jan 05 2018 12:28 PM
California
W
wayno48 Offline
wayno48  Offline
W
California
If it was permitted the building department should have the stamped approved truss calculation on file. It looks like you have 2x6 bottom cords. That should be plenty strong.
Re: Hanging Signs in a Pole Building [Re: BryceG] #701898
Fri Jan 05 2018 12:55 PM
Done4 Offline
Done4  Offline
Bryce, for what it's worth your truss design is very similar to mine which you have seen and to date all is good. Hope I didn't just jinks myself?
Re: Hanging Signs in a Pole Building [Re: BryceG] #701904
Fri Jan 05 2018 02:06 PM
Erie Pa
Bill jr Offline
Bill jr  Offline
Erie Pa
My trusses are 2 ft OC and I have 6 ft porcelain signs hanging from them plus snow but they are within 8ft of the wall
Re: Hanging Signs in a Pole Building [Re: BryceG] #701914
Fri Jan 05 2018 04:34 PM
Calgary AB
Gasman84470 Offline
Gasman84470  Offline
Calgary AB
No winter in Peoria Bryce? Looks like you'll have plenty of room for your "stuff"
Re: Hanging Signs in a Pole Building [Re: Gasman84470] #701916
Fri Jan 05 2018 04:57 PM
Peoria, IL
BryceG Offline OP
BryceG  Offline OP
Peoria, IL
actually the opposite... way too much winter here in Peoria! we've been seeing temps dip to -20 windchill for several days in the past week. here's the project currently, too cold to even work on the garage doors so i opted for tarps, ha.
Page Time: 0.026s Queries: 16 (0.007s) Memory: 1.9215 MB (Peak: 2.0782 MB) Zlib disabled. Server Time: 2018-06-21 11:53:36 UTC
