Re: Erie 70 finally all done... [Re: Rabbitman] #699464
Tue Nov 28 2017 08:37 AM
Washington
Signal Oil Offline
Signal Oil  Offline
Washington
Great work! Where did you find the lettering for the top? Is it custom made?
Scot
Looking for nearly anything related to Signal Oil
Go Farther!
Re: Erie 70 finally all done... [Re: Rabbitman] #699469
Tue Nov 28 2017 10:49 AM
Missouri,USA
Rabbitman Offline OP
Missouri,USA
Thanks for all the compliments.The lettering on the top is custom made. I found an advertising company that cuts lettering to spec out of about any material. I wanted them in brass or stainless but wasn't sure the idea was going to work so didn't want to pay that much to experiment. These were water jet cut out of plastic and the material was already the gold metallic color that closely matched my gold trim stripes on the doors so I ended up leaving them as is and didn't even paint them. They are just clear epoxied to a thin stainless strip that attaches to the top with a single small screw in the center where there was an existing hole. The strip and screw are almost hidden completely under the dome. I can find the name of the company that I got the letters from if anyone is interested. They can cut letters to any size/space confinement but if you went with more than six or seven letters they would get pretty short. I would be glad to help if anybody would like to get some made for their pump.....GB
Re: Erie 70 finally all done... [Re: Rabbitman] #699597
Fri Dec 01 2017 07:48 AM
Washington
Signal Oil Offline
Signal Oil  Offline
Washington
Thank you for the information. I will keep it in mind when I start my restoration.
Cheers!
Go Farther!
Re: Erie 70 finally all done... [Re: Rabbitman] #699598
Fri Dec 01 2017 08:50 AM
Missouri,USA
Missouri,USA
Scot, if you are doing yours in Signal, the letters would look killer on there. The Signal colors would make a great looking 70...GB
Page Time: 0.021s Queries: 14 (0.008s) Memory: 1.8572 MB (Peak: 1.9424 MB) Zlib disabled. Server Time: 2018-12-17 09:50:55 UTC
