#689154
Sat Jun 24 2017 08:07 PM
Posts: 41 Likes: 1
Posts: 41 Likes: 1 |
Hi. If it is a Wayne...what model? I see a lot of model 70 pumps that look similar, but not exactlying the same. Thanks for any help.
Wayne 70--just a model without the ad glass. Looks short though? Hard to tell from the picture. How tall is it?
Posts: 41 Likes: 1
Frith, thanks for the response. It is about 5.5 feet tall. Does that height make it a short or a tall? I assume short, yes? There is a bracket on top to house a globe/sign
Posts: 265 Likes: 24
Posts: 265 Likes: 24 |
Mine measures 74 inches, may have been cut down. Brian
Posts: 41 Likes: 1
Wow. Cool pump Brian. Thanks for sharing. Yours is obviously taller. The space between the sight glass and top is the obvious difference.
Posts: 41 Likes: 1
Missing upper & lower access panel in rear. Still has all the guts inside. Is this worth $600? That's what the man is asking for it
Posts: 1,663 Likes: 25
Posts: 1,663 Likes: 25 |
I would pass. The door is probably gonna cost you $150 & then you will have to cut it to fit your pump. You can probably find a complete pump for $750. Chris
IMO 600 would be a decent deal if it wasn't cut. But I believe it is. With no ad glass and stubby,it's kind of a doggy looking thing -to me.
Posts: 41 Likes: 1
It was not cut. It was removed from a barn. I believe it is just a Wayne 70 short. The gap between the sight glass and the top is unlike any others I've seen. Perhaps they just made this pump in a short version?
Posts: 41 Likes: 1
If this pump was cut down from the base how do you explain the location of the sight glass compared to the top of tank? Tall pumps sight glass is much lower
It was not cut. It was removed from a barn. I believe it is just a Wayne 70 short. The gap between the sight glass and the top is unlike any others I've seen. Perhaps they just made this pump in a short version? Perhaps nothing! Wayne made a model 100 and did not make a 70 short. The 100 resembles a 70 and was Waynes answer to the need for shorter pumps. Wayne made a lot of different versions of the 70 but never a "short". Yours is a cut down version of one of those model variations.
Posts: 1,906 Likes: 50
Posts: 1,906 Likes: 50 |
X 2 I like Wayne 70's but would have a pretty hard time paying $600 for that.
I bet if you look at the inside bottom edge of door there is no 90degree bend, just straight where it has been cut. There is no such pump as a short Wayne 70.....unless it has been cut. Chris
Posts: 41 Likes: 1
Frith is right. I think it is a Model 100. Thank you, sir! I appreciate all the suggestions. I will try to get it for less,
That is a cut down 70 also, not a Wayne 100. Wayne 100's have a wide window, and sight glass in the face. Here is a pic of a 100
Posts: 2,995 Likes: 110
Posts: 2,995 Likes: 110 |
Johnny,
Listen to the experts. It IS a cut down 70. There is NO SUCH THING as a short 70. And it is DEFINATELY NOT a Wayne 100 (and neither is that Pure pump, it is also a cut down 70, the advertiser/auction house has it listed wrong).
-Steve
Posts: 217 Likes: 6
Posts: 217 Likes: 6 |
I think it's a factory short Wayne 70. I have seen 2 others just like it and nothing was modified.
Posts: 406 Likes: 33
Posts: 406 Likes: 33 |
I find it interesting that more than one of these pumps has shown up with out their ID tags.
Randy
Posts: 1,206 Likes: 13
Posts: 1,206 Likes: 13 |
CGGAS is correct, a cut down 70. They were cut down by pump repair/aftermarket companies like Partee in Spencerville Indiana among others.
If you open the door and look several inches down from the very top you will see the horizontal weld line where they were shortened, all shortened ones that look like yours will have that weld there, only visible from the inside. I would like to know the weld process they used, almost looks like a robot weld but this was done back in the 1950's.
Tom.
Posts: 715 |
Interesting topic. They cut a lot of Wayne 70s, certainly a disproportionate amount vs. other style pumps. I've seen several of these "short" 70s.
There's no stopping the Cretins from hopping You've got to keep it beating for the hopping Cretins
Like Tom says, they did a beautiful job welding the seams on the doors, can't even see the seams until u open the doors. I've also seen a lot of tokheim 39's cut down.... but cut 70's seem to be the most popular cut down pump by far.
Posts: 41 Likes: 1
Additional pics...does this help?
Posts: 41 Likes: 1
ID plate? It's all that is there...
Posts: 41 Likes: 1
How bout a pic of the back of the door? I'd tag should be on the side acess door.
Posts: 41 Likes: 1
I think this is where the tag was at one time, yes?
