Very old Red Indian can #686868
Mon May 15 2017 08:53 PM
MB
M_F_S Offline OP
M_F_S  Offline OP
MB
Im looking for help putting a value to this cool can i have come across.Any help would be much appreciated smile I know it's in pretty rough shape on the one side and the can is fairly squished but from what i know its super rare to find...
Re: Very old Red Indian can [Re: M_F_S] #686889
Tue May 16 2017 07:34 AM
Vancouver, BC
muntzman Offline
muntzman  Offline
Vancouver, BC
What a shame. A very rare tin in very bad shape. I would open it up and straighten it as best you could. Then in my opinion it might be worth a couple hundred.
Re: Very old Red Indian can [Re: muntzman] #686893
Tue May 16 2017 09:17 AM
MB
M_F_S Offline OP
M_F_S  Offline OP
MB
How do u open it up? Like from the cap? I think i will keep it as is but yes it is pretty beat up. So only a cpl hundred eh frown
Re: Very old Red Indian can [Re: M_F_S] #686940
Tue May 16 2017 10:21 PM
MA
thebmwjunkie Offline
MA
I'd agree with the couple hundred estimate above, the condition is just too far gone for many collectors. But who knows, throw it on eBay (if you're selling it) and you may get a bidding war
Re: Very old Red Indian can [Re: M_F_S] #686944
Wed May 17 2017 02:08 AM
Ontario,Can
junior25 Offline
junior25  Offline
Ontario,Can
Highly sought after can that pre-dates 1918, although it certainly has condition issues. Hard to give an exact value of a can like this given it's condition, but in todays crazy marketplace who knows. I can see 2 people at auction paying north of $200 just to own one.
Daryl
Re: Very old Red Indian can [Re: junior25] #686976
Wed May 17 2017 02:26 PM
Cleveland,Ohio U.S.A.
JimT Offline
JimT  Offline
Might make it kinda rounded but I have blown out dents with compressed air...
Re: Very old Red Indian can [Re: M_F_S] #686988
Wed May 17 2017 04:23 PM
MB
M_F_S Offline OP
M_F_S  Offline OP
MB
I think ill try the compressed air idea. I also use metal rescue from time to time with some pretty good rust removal results.Thanks Everyone
Re: Very old Red Indian can [Re: M_F_S] #687005
Wed May 17 2017 07:18 PM
Kelso,Wa
trifiver Online content
trifiver  Online Content
Kelso,Wa
Low pressure
too much (bang)
www.trifivechevys.com
www.knifegates.com
Re: Very old Red Indian can [Re: M_F_S] #687006
Wed May 17 2017 07:19 PM
Kelso,Wa
Kelso,Wa
I would used Water
Much safer
Sid
www.knifegates.com
Re: Very old Red Indian can [Re: trifiver] #687010
Wed May 17 2017 08:19 PM
JimT Offline
JimT  Offline
Might be worth making a box somehow so the sides and bottom cant go past the desired point.
Re: Very old Red Indian can [Re: M_F_S] #687021
Thu May 18 2017 05:17 AM
Carthage, IN USA
tbuckles Offline
tbuckles  Offline
Carthage, IN USA
If the can is air tight set it in a large pan of water on the stove and slowly heat the water. As the air inside gets hot it expands and pops the dents out. The slower you heat it the more control of the rate of expansion.
This was a school science experiment. When the can was hot we loosened the cap to let the hot air out and retightened the cap then as it cooled the can sucked in and crushed, set it back in the hot water and watched it pop back out. I'd try it on a junk can first. Disclaimer....I'm not saying how safe this is, you know back in the sixties it didn't seem like we worried about such things as much...lol
Tom.
Carthage Indiana
Re: Very old Red Indian can [Re: M_F_S] #687025
Thu May 18 2017 06:28 AM
Devils Lake, ND---USA
K W FRITH Offline
K W FRITH  Offline
Compressed air is a bad idea because there is too much lack of control. Once you go too far and ruin the can, you can't go back! I'm speaking from experience here!
Tom's idea is much better.
Re: Very old Red Indian can [Re: M_F_S] #687031
Thu May 18 2017 07:24 AM
Duluth, MN U.S.A
Ryan Underthun Offline
Duluth, MN U.S.A
I have fixed snowmobile pipes that had dents in them by filling them with water and then freezing. Not sure if it would work on an oil can though, never tried.
visit my website for original gas pumps and parts
www.thepumpdump.com
Re: Very old Red Indian can [Re: tbuckles] #687033
Thu May 18 2017 07:50 AM
CT, USA
jecos Offline
jecos  Offline
CT, USA
The method described by Tom is a fairly well controlled experiment,if the sealed vessel is dry. The temperature inside the vessel is limited by the boiling point of water. So as long as there is water in the pot, the temperature will not exceed 100C. Based on this, the max pressure (differential) that can be reached inside the can is about 3.5 psi above room pressure. (But if there's any liquid inside the can, it would get a lot higher.)
The problem is the rupture strength of the can in question. 3.5 psi is actually a pretty large internal pressure differential for a thin sheet metal can with a rectangular geometry. To put this in perspective, if a can wall is something like 9" x 7", the force exerted on it would be over 200 lbs, equally distributed. Add in the age, rust and the dent-induced stresses on the metal and you have a good chance for catastrophic failure if you seal the can tightly.
Re: Very old Red Indian can [Re: M_F_S] #687043
Thu May 18 2017 11:41 AM
Calgary AB
Gasman84470 Offline
Gasman84470  Offline
Calgary AB
Sounds like an experiment to do at your buddy's place...carefully...good luck
Re: Very old Red Indian can [Re: M_F_S] #687216
Sun May 21 2017 02:13 PM
MB
M_F_S Offline OP
M_F_S  Offline OP
MB
Thanks Everyone...I'm not sure what i'll do. Maby I will just keep it as is. The can doesn't hold air and is pretty bent..
Re: Very old Red Indian can [Re: M_F_S] #687708
Wed May 31 2017 09:37 AM
alberta
canadianoilguy Offline
alberta
unsolder the bottom, get in there with a hammer and dolly (make sure outside paint is protected) and solder back together
Always looking for Red Indian Tins, McColl Frontenac, McColl Bros., Buffalo (prarie cities oil co), Stellarene and other western canadian tins.
Moderated by  Oldgas
Page Time: 0.044s Queries: 15 (0.008s) Memory: 1.9301 MB (Peak: 2.0961 MB) Zlib disabled. Server Time: 2018-04-22 18:27:32 UTC
