#682048
Sun Mar 12 2017 10:27 PM
Posts: 2,488 Likes: 2
Posts: 2,488 Likes: 2 |
What is the best way to shorting a hose with original one? Thanks
Posts: 2,457 Likes: 24
Posts: 2,457 Likes: 24 |
Buy a shorter hose. No easy way to shorten a hose unless you have the tools. If there is a hydraulic, air hose supply shop locally, they might be able to do the deal? Otherwise, my first statement causes less pain. Paul www.severngaspumps.com
Posts: 196 Likes: 2
Posts: 196 Likes: 2 |
Depending on the dia. of the hose u could buy a replacement end and and cut your hose and replace the end.
I collect Phillips 66 and globes pumps & signs esp Iowa co.
Scott-You probably know all this- the ends are crimped on with a hydraulic machine. either 1)buy a shorter one -they are pretty inexpensive. 2)shorten it and try to talk some one into crimping a new fitting on. 3)shorten it and try to dig the end of the hose out and reattach it some how to your end. 4)cut a section out of the middle and shove a tube in like a splice. 5) they make a high pressure splicing kit that involves a series of fittings that ends up about 6 inches long but will cost about as much as as buying a new one. I think that sums up your options.
Posts: 1,871 Likes: 48
Posts: 1,871 Likes: 48 |
That hose actually belongs inside the pump and comes out on the side of the retractor plate below the nozzle, so for that pump I think it is the correct hose length.
Posts: 1,655 Likes: 24
Posts: 1,655 Likes: 24 |
The retractor on these holds a cable, the hose stays out. Maybe just put a 3in pipe in hose outlet... cut hose push it on pipe & use a band-it clamp to attach hose to short piece of pipe? Chris
As said the hose is inside on a counter weight that pulls it back into and down when not in use. There is no cord on this pump.
Thanks for the help. the cord is there but not hooked up. I guess what I wanted was the hose not to drag on the ground, but close to the ground. I see that hooking the cable up would pull it back. But would it pull it up enough? Thanks Again
I've never seen a Wayne 80 that the hose retracts inside? I've only seen them with retractor cables? Chris
I hooked it up. But it looks bad I think. Any ideas?
Scott, contact your local Tractor Repair Facility or if you have an Industrial Hyd. Hose Facility and ask them... I had a long hose shortened by such a Facility here in my Community and the cost was less than $50....
Thanks bob. That is where I am off to. I don't like the look now. Thank again for all the help.
According to my M&S/Wayne literature for the 80, they did not make a 80 with a hose on a reel.
Jack so the cable is not right? It looks original to me.
On any gas pump the cable is used to pull back the hose so it was not laying on the ground, your "outside" hose as M&S/Wayne called them is correct.
I never got around to it, but years ago I purchased the wire, brass couplers and the part that clamps on the hose, with the idea of offering them for sale. Still out in the garage in a drawer.
