Page 1 of 3 1 2 3
#676567 Fri Jan 13 2017 12:11 PM
T-way Offline OP
As some of you know, I have a very large ‘Chicken Coop’ that has been converted into my shop, studio and Man Cave. The building itself is about 3.5K square feet.
In my Man Cave there is a three sided ‘U’ shaped display case unit. The two sides are glass topped with display areas under the glass for smaller items and the end is open fronted with a wood countertop and lighting under the countertop to illuminate the objects below.
I’ve never liked the countertop. It was just quickly finished years ago by throwing a coat of stain on the plywood surface – not even a coat of poly. My fault, and I’ve been planning on addressing the problem literally for years.
Last fall, I stripped some 100+ year old barn wood from a barn that was falling down. I also picked up a couple of barn beams.
I decided it was time to do something about the countertop.
Here is a shot of the area after I stripped off the face trim, and trimmed back the plywood flush with the support structure.
T-way #676568 Fri Jan 13 2017 12:12 PM
T-way Offline OP
So I took the longest barn beam I had and cut a square notch into one corner . . .
T-way #676569 Fri Jan 13 2017 12:13 PM
T-way Offline OP
. . . and mounted it to the front of the counter.
T-way #676570 Fri Jan 13 2017 12:13 PM
T-way Offline OP
Then I trimmed off the ends and added 45-degree cuts on the ends to eliminate the sharp corners and framed up the left, right and back sides with other 100 year old barn wood to enclose the center area.
T-way #676571 Fri Jan 13 2017 12:16 PM
T-way Offline OP
I then lightly sanded everything to eliminate any chance of splinters. But I left as much of the saw mill cut marks as possible to preserve the character. Here’s a shot of the backside after framing and before final staining and poly.
T-way #676572 Fri Jan 13 2017 12:17 PM
T-way Offline OP
After stain and poly . . .
T-way #676573 Fri Jan 13 2017 12:17 PM
T-way Offline OP
Then I added stacked stone to the back wall . . . and ceramic tile that looks like barn wood on the bottom.
T-way #676574 Fri Jan 13 2017 12:19 PM
T-way Offline OP
I then had a contractor come in and pour a cement countertop in the recess.
T-way #676575 Fri Jan 13 2017 12:19 PM
T-way Offline OP
Here is the finished project showcasing Jodi’s Ice Cream globes.
T-way #676576 Fri Jan 13 2017 12:45 PM
Nice job! You did one heck of a job, it looks great. Hope you don't have to move it.
T-way #676577 Fri Jan 13 2017 12:54 PM
That looks fantastic! Nice re-use of the old barn beam.
Regards, Jim
T-way #676578 Fri Jan 13 2017 12:56 PM
That is sweet!!
T-way #676583 Fri Jan 13 2017 01:44 PM
Looks great Jim!
T-way #676584 Fri Jan 13 2017 02:50 PM
Very unique and well done.
T-way #676587 Fri Jan 13 2017 03:04 PM
Pretty classy chicken house there!!!
Page 1 of 3 1 2 3
