Page 1 of 4 1 2 3 4
POTM "pump of the month" Bennett Feb 2015 #595590
Sun Feb 01 2015 01:36 PM
Cameron Park,Ca.
MATT ALVAREZ Offline OP
Cameron Park,Ca.
There was talk a while back about doing pump of the month. No one started it So I will try. I can not guarantee I will do it every month. This month we will do bennett 300 and 500 series. We will also include Bennett 76 and 77. I will start with info for 300 and 500 but post your 76 and 77s any time.
The 300 series included 371,372,373,383(not including Gulf)and were made from 1938-1941. The 371 has a computing Veeder Root, 373 is a twin, 373 is a non-computing clock unit and the 383 is a non-computing Veeder Root.
The 500 series included 541,542,543,545( not including Gulf)and were made from 1939-1941. There was also the 546,566,567 with the sight glass at the top in place of the ad glass. the 541 has a computing Veeder Root, 542 is a twin,543 has a non-computing Veeder Root,545 is a non-computing clock unit, 545 is a computing unit, 566 is computing with a hose retractor and 567 is non-computing with hose retractor and was made from 1940-1941.
The two series look the same but not many parts are interchangable. The frame are the biggest difference. I will post several pictures of the differences. We will start with pictures of the frames and on-off levers. The on-off lever is the only way to tell the two series apart with out opening the door. Also note in the frame pictures the door latching systems. If I do not note it the firt picture will be the 300 series and second 500 series.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595592
Sun Feb 01 2015 01:41 PM
Cameron Park,Ca.
Cameron Park,Ca.
The 300 has for hinges on each side the 500 has three.
Some 300s used the 500 style reset handle, first pic is the 300 and looks kind of like a G&B handle.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595599
Sun Feb 01 2015 01:49 PM
Cameron Park,Ca.
Cameron Park,Ca.
There were East coast and West coast light units. The west coast have explosion proof with the glass jars and East just had light reflectors. I only have pics of West coast.
The Eary 300 nozzle receivers were cast iron with bolt on the inside. Later ones and 500 series screws on the outside.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595604
Sun Feb 01 2015 01:56 PM
Cameron Park,Ca.
Cameron Park,Ca.
The ID tags are different and another way to tell the two series apart with out opening the door. That is if you can read it on a unrestored pump.
The hose outlets were the same but there were 3/4 and 1 inch sizes. Als found a 90 degree one most were a 45 degree. There was also a safty shut off style.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595607
Sun Feb 01 2015 02:02 PM
Cameron Park,Ca.
Cameron Park,Ca.
The 300 series faces were flat and used a steel mounting pan. They were aluminum. I do have one flat porcelain set and seen one other set. The 500 used a one piece face with rolled sides. They came in aluminum and porcelain. The 546,566 and567 used both styles of faces.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595609
Sun Feb 01 2015 02:06 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here are picture of the twin parts. The twin is basically two single pumps joined together. The bases have a flat spot to join the and the reset is on the hose side. These pictures are from a 542.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595612
Sun Feb 01 2015 02:10 PM
Cameron Park,Ca.
Cameron Park,Ca.
Gas Pump Blue Book codes. On these goes by the letter in your seial number. If there is two letters it is the second letter.
J - 1938
K - 1939
L - 1940
M - 1941
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595616
Sun Feb 01 2015 02:15 PM
Cameron Park,Ca.
Cameron Park,Ca.
Interchangeable parts include:
top sheet metal
globe holder
access door
hose outlet ans bezel
sight glass assembly (diffferent on 546,566.567)
ad glass and door glass retainers
faces, even though they are different
reset handles
Feel free to post pictures. I will post my pumps ans a little 76,77 info later.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595638
Sun Feb 01 2015 03:25 PM
Parkersburg, WV 26101
Keystone Gas Man Offline
Thanks Matt, I have a 371..Keep it coming!
Re: POTM "pump of the month" Bennett Feb 2015 [Re: Keystone Gas Man] #595640
Sun Feb 01 2015 03:26 PM
Bardstown, KY USA
philmccauley Offline
Bardstown, KY USA
Good job Matt.
Thanks, Phil
Re: POTM "pump of the month" Bennett Feb 2015 [Re: philmccauley] #595695
Sun Feb 01 2015 07:05 PM
Cameron Park,Ca.
Cameron Park,Ca.
The Bennett 76 and 77 came in an early and later version with both versions having a two or four ad glass top. These were also sold with SSE 76, 77 ID tags (Service Station Equipment). They were made from 1935 to 1939. The early model has a external visi guage and a one piece casted face bezel with the trim part chrome plated. Some of the real early models had a cast iron top, the rest a pot metal top. The later model has a sight glass in the face with cut outs in the trim area and separate stainless trim that fit in place. The 76 is a computing pump with a Veeder Root and the 77 is a non-computing pump with a clock unit. The early model had a different reset handle the the later. These pumps also had east ans west coast light units like the 300 and 500 series. There was also a special face bezel made for Sohio. I do not have a lot of pictures of these pumps but do have an early and late model.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595696
Sun Feb 01 2015 07:08 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here are the faces
Here are the handles
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595699
Sun Feb 01 2015 07:16 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here is the east cast and west coast light units.
Here is a later 77 with four ad glass top.
Early 76 and visi gauge
Blue book dates, same as above
F 1935
G 1936
H 1937
J 1938
K 1939
Let`s see your pumps
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595702
Sun Feb 01 2015 07:24 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here are some of mine. I forgot to mention that the 300 and 500 series came with four, two, or no ad glass. The 546, 566, 567 came in two or no ad glass.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595703
Sun Feb 01 2015 07:29 PM
Cameron Park,Ca.
Cameron Park,Ca.
If anyone wants their pump posted and has trouble getting pictures on here you can email them to me and I will ad them. My email is in my profile.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595706
Sun Feb 01 2015 07:35 PM
Zumbrota, MN
bowserman Offline
bowserman  Offline
Zumbrota, MN
This is my SSE 76 before I got a visi for it. I have it torn down and blasted right now and prepping for primer and paint.
- Jacob -
Email: jake5246@hotmail.com
Cell 507-259-2601
Re: POTM "pump of the month" Bennett Feb 2015 [Re: bowserman] #595730
Sun Feb 01 2015 09:04 PM
Calgary AB
Gasman84470 Offline
Gasman84470  Offline
Calgary AB
Matt thanks for doing this. I will not see many of these pumps in real life so I appreciate the chance to see them here in such detail. Now if I can remember one tenth of what you've shown so far!
Re: POTM "pump of the month" Bennett Feb 2015 [Re: Gasman84470] #595748
Sun Feb 01 2015 09:46 PM
Hays, Kansas
bsplichal95 Offline
bsplichal95  Offline
Hays, Kansas
Amazing job Matt, That takes a lot of time and work to do this. You have done a great job. I have learned a lot. Now if only I had one to post!
Re: POTM "pump of the month" Bennett Feb 2015 [Re: bsplichal95] #595758
Sun Feb 01 2015 10:07 PM
Cameron Park,Ca.
Cameron Park,Ca.
Thanks for the complements. Glad you are enjoying it, it is a lot of work. Future ones may not have as much information. Bennetts are one of my favorite pumps and I own several. I am thinking about one in the future for 600, 700, 900 and 1000 series Bennetts.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: bsplichal95] #595759
Sun Feb 01 2015 10:08 PM
Dave's Garage Offline
Matt, very informative and I appreciate all the effort and time put forth by you to do this. Good reference material for future users.
Dave GILL,
Re: POTM "pump of the month" Bennett Feb 2015 [Re: Dave's Garage] #595770
Sun Feb 01 2015 10:43 PM
Cameron Park,Ca.
Cameron Park,Ca.
bennett 391, does anyone have one? I can not find any information on one. This one was on ebay a while back. It looks like a 546 but has a 300 series on-off lever and the ID says 391 but is a newer style ID tag. They did not show the inside and wonder if it has a pipe frame.
Here is an original oil painting I bought. There were no prints made of it so it is a one and only. While image surfing I found the image that was used to do the painting.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: Dave's Garage] #595771
Sun Feb 01 2015 10:48 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here is the last of my 300, 500 series Bennetts.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595820
Mon Feb 02 2015 07:40 AM
Easley, SC
Lappin864 Offline
Lappin864  Offline
Easley, SC
Matt, that Hancock is sharp! I love your "rustoration"
-Searching: Anything to do with SC, NC, GA oil companies, Outboard Cans, Anything Gulf, Tokheim 850
Re: POTM "pump of the month" Bennett Feb 2015 [Re: Lappin864] #595866
Mon Feb 02 2015 02:18 PM
Zumbrota, MN
bowserman Offline
bowserman  Offline
Zumbrota, MN
Pics of a frame for a 76 w/ Visi-Guage
20150202_151056_resized_1_resized.jpg20150202_151005_resized_resized.jpg20150202_150928_resized_resized_1.jpg
- Jacob -
Cell 507-259-2601
Re: POTM "pump of the month" Bennett Feb 2015 [Re: bowserman] #595929
Mon Feb 02 2015 10:09 PM
Cameron Park,Ca.
Cameron Park,Ca.
Thanks for posting your 76 frame. I did not mention that the 76 and 77 had a pipe frame. Most pumps before the late 30s had pipe frames. There are some pumps that the frame is part of the visable outer portion like Wayne 60s, M&S 70s and G&B 70, 80, 86.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595989
Tue Feb 03 2015 09:46 AM
Whitefish Montana
cak Offline
cak  Offline
Whitefish Montana
Love the Hancock pump amazing colours!!!!!! Great job Matt!!!!
Re: POTM "pump of the month" Bennett Feb 2015 [Re: cak] #596069
Tue Feb 03 2015 06:17 PM
Mass.
gasmelincelr Offline
Mass.
Nice effort Matt!
I hope to restore my 76 this year or next.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: gasmelincelr] #596079
Tue Feb 03 2015 07:16 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here is petro & rodz Bennett 383 Station Lighter. Have not seen very many 300 or 500 series Bennett Station Lighters. Nice pump!!!!
Also do not see the original non-computers very offten, double rare on this one.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596084
Tue Feb 03 2015 07:32 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here is a close up of the non-computer face. Notice there is no total dollar amount, just how much per gallon. That is why it is a non-computer, it does not calculate the total price. it just shows the gallons dispensed. It also only has one totalizer (little slot with tiny numbers)instead of two.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596140
Wed Feb 04 2015 04:32 AM
western ky
petro & rodz Offline
western ky
This pump is a 373-F .
Re: POTM "pump of the month" Bennett Feb 2015 [Re: petro & rodz] #596275
Wed Feb 04 2015 09:06 PM
Cameron Park,Ca.
Cameron Park,Ca.
The 373-F of just a 373 is a clock face pump. The 383 has a non-computing Veeter Root like what is in your pump. It must of had the clock swithched out at one time or the access door with the ID tag could have been changed. I seen a Bennett 371 that had an ID tag that said 542. Either way your pump is awesome. Thanks for sharing it with us.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596278
Wed Feb 04 2015 09:21 PM
Cameron Park,Ca.
Cameron Park,Ca.
So far there has not been much participation, so I will add some pictures of gas stations with Bennetts. Thank to those that have shared there pumps with us, a couple nice 76s and a nice station lighter.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596279
Wed Feb 04 2015 09:24 PM
Cameron Park,Ca.
Cameron Park,Ca.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596304
Thu Feb 05 2015 05:08 AM
Oklahoma
texacokie Offline
texacokie  Offline
Oklahoma
I picked up a 76 I will post some pics soon when it warms up around here
Re: POTM "pump of the month" Bennett Feb 2015 [Re: texacokie] #596382
Thu Feb 05 2015 03:08 PM
clio, michigan usa
r49th Offline
r49th  Offline
clio, michigan usa
I've only managed to have 546's pass through here. Three of them at that. They do make for a nice pump to work on.
ROD [Mich.]
Re: POTM "pump of the month" Bennett Feb 2015 [Re: r49th] #596451
Thu Feb 05 2015 09:58 PM
USA
keithia Offline
keithia  Offline
USA
Here are a few I have.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: keithia] #596455
Thu Feb 05 2015 10:52 PM
Cameron Park,Ca.
Cameron Park,Ca.
Nice pumps, thanks for posting.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596479
Fri Feb 06 2015 06:32 AM
Easley, SC
Lappin864 Offline
Lappin864  Offline
Easley, SC
Here's my Bennett. Need the bezel for the other side and I can finally start the "rustoration." It was inspired by you Matt. You do such an awesome job on all of your pumps!
Re: POTM "pump of the month" Bennett Feb 2015 [Re: Lappin864] #596516
Fri Feb 06 2015 10:28 AM
Los Alamitos, CA
dfranchi Offline
dfranchi  Offline
Los Alamitos, CA
Here are two pics of my 371 - restored by Dave Folck. Four ad glass
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596624
Fri Feb 06 2015 08:45 PM
western ky
western ky
Matt did a little cleaning on tag on my pump and you nailed it .it is a 383. I've been mistaking the 7 for 8 .Sorry for my oversight pal.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: petro & rodz] #596627
Fri Feb 06 2015 09:23 PM
Cameron Park,Ca.
Cameron Park,Ca.
This is great seeing all these Bennetts and thanks for the complements. A lot more 76s being posted than I thought there would be.
The Union 76 is nice, I think I seen it being built. I was at Dave`s house four years ago picking up a parts 371 Bennett. There was one being assembled.
Randy, I am glad your pump is 100% original. I bet you are happy to know some one has not messed with it.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: petro & rodz] #596629
Fri Feb 06 2015 09:28 PM
Missouri,USA
Rabbitman Online content
Rabbitman  Online Content
Missouri,USA
Here's my 76. It was posted back in December when I finished it but thought I'd add it to this thread. Love all the posts so far and hope the POTM keeps going again. There are so many variations of all of the pumps that it's really a great learning experience to bring everyone's input to one thread. I'm on the hunt for more Bennett pumps to add to my collection. Keep em comin guys...
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596631
Fri Feb 06 2015 09:35 PM
Cameron Park,Ca.
Cameron Park,Ca.
We have not seen a 373 yet so here is a new face, original hands and a clock mechanism. The white face pan is for a 300 series Veeder Root and the rusty one is for a 373 clock. The cross bars are the only difference. The 77 uses the same clock mechanism.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596644
Sat Feb 07 2015 01:21 AM
A few Bennetts.
Dave GILL,
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596773
Sat Feb 07 2015 05:37 PM
Alabama, USA
Dale Stephens Offline
Alabama, USA
Matt:
Here's the ones I have...
Re: POTM "pump of the month" Bennett Feb 2015 [Re: Dale Stephens] #596811
Sat Feb 07 2015 08:35 PM
Cameron Park,Ca.
Cameron Park,Ca.
Thanks Dave & Dale for the additions.
Dave, I like the worn Shell. I have a picture of it you posted in the past and it had more red on it.
Dale, I love your Shell wall
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #596813
Sat Feb 07 2015 08:44 PM
Alabama, USA
Alabama, USA
Thanks, Matt, for the compliment.....Dale
Re: POTM "pump of the month" Bennett Feb 2015 [Re: Dale Stephens] #597431
Tue Feb 10 2015 03:43 PM
Spring Valley,Illinois
pumpdoc Offline
pumpdoc  Offline
This my Bennett.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: pumpdoc] #597432
Tue Feb 10 2015 03:46 PM
pumpdoc Offline
pumpdoc  Offline
[img] [/img]
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #686583
Fri May 12 2017 10:46 PM
Speedracer Offline
Speedracer  Offline
First off, I realize this is a two year old thread. However, I am bringing it back for informational purposes. I recently bought what I thought was a common Bennett pump. When I got it home I realized it was a Bennett 391, which there is not a lot of information on - at all. I saw that Matt Alvarez put a lot of work into this thread and I wanted to complete it a little more for those who may need the info for future use (just as I used this thread last week - along with almost 10,000 other views). It's still a fairly common style pump, but if someone has to ID one without a tag, maybe this will help. So here is the Bennett 391... and she's a rough one.
Date of Manufacture: According to my Blue Book the 391 was only made in 1939 (and has a K on the tag).
Frame: Pipe
Computer: Computing Veeder Root
Ad glass: None
Door Hinges: 4 - same as other 300 series pumps
Door latches: 4 latches along side rail, with internal lift lever
Hose outlet: 45 degrees
Face Plates: Missing - I assume they had to be flat and porcelain, since the sight glass was up above. All the above pictured Bennett's without ad glass and the sight glass up top have porcelain faceplates.
I.D. Tag/badge: This 391 uses a 500 series style I.D. tag.
One last thing I wonder about the 391, is if maybe the model number 391 was designated for The Standard Oil Company (and/or its affiliates). My pump has original paint and the globe ring on top is an original contoured 7" ring made for a Crown globe (or affiliates). This is just merely a guess/possible theory.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #686584
Fri May 12 2017 10:49 PM
Speedracer Offline
Speedracer  Offline
a few more...
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #686606
Sat May 13 2017 10:03 AM
Cameron Park,Ca.
Cameron Park,Ca.
Steve, thanks for adding this information.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #686640
Sat May 13 2017 08:58 PM
Cameron Park,Ca.
Cameron Park,Ca.
After this thread I was able to add five more pumps to my collection and a parts pump I am trying to piece together. The first was a few months after this thread. It is the Bennett 77 that I posted earlier in the thread. I was able to make a deal on it, added some ad glass, a globe and turned it around. The back side against the fence has a good decal. Two of the additions are 541s and the other two are 373s. The parts pump is a 371. It is the one with the plastic Shell pump plate. It is missing a door and some small parts.
Page 1 of 4 1 2 3 4
Page Time: 0.065s Queries: 26 (0.011s) Memory: 2.1633 MB (Peak: 2.5811 MB) Zlib disabled. Server Time: 2018-04-25 18:04:44 UTC
