Page 1 of 4 1 2 3 4
POTM "pump of the month" Bennett Feb 2015 #595590
Sun Feb 01 2015 01:36 PM
Cameron Park,Ca.
MATT ALVAREZ Offline OP
Cameron Park,Ca.
There was talk a while back about doing pump of the month. No one started it So I will try. I can not guarantee I will do it every month. This month we will do bennett 300 and 500 series. We will also include Bennett 76 and 77. I will start with info for 300 and 500 but post your 76 and 77s any time.
The 300 series included 371,372,373,383(not including Gulf)and were made from 1938-1941. The 371 has a computing Veeder Root, 373 is a twin, 373 is a non-computing clock unit and the 383 is a non-computing Veeder Root.
The 500 series included 541,542,543,545( not including Gulf)and were made from 1939-1941. There was also the 546,566,567 with the sight glass at the top in place of the ad glass. the 541 has a computing Veeder Root, 542 is a twin,543 has a non-computing Veeder Root,545 is a non-computing clock unit, 545 is a computing unit, 566 is computing with a hose retractor and 567 is non-computing with hose retractor and was made from 1940-1941.
The two series look the same but not many parts are interchangable. The frame are the biggest difference. I will post several pictures of the differences. We will start with pictures of the frames and on-off levers. The on-off lever is the only way to tell the two series apart with out opening the door. Also note in the frame pictures the door latching systems. If I do not note it the firt picture will be the 300 series and second 500 series.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595592
Sun Feb 01 2015 01:41 PM
Cameron Park,Ca.
Cameron Park,Ca.
The 300 has for hinges on each side the 500 has three.
Some 300s used the 500 style reset handle, first pic is the 300 and looks kind of like a G&B handle.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595599
Sun Feb 01 2015 01:49 PM
Cameron Park,Ca.
Cameron Park,Ca.
There were East coast and West coast light units. The west coast have explosion proof with the glass jars and East just had light reflectors. I only have pics of West coast.
The Eary 300 nozzle receivers were cast iron with bolt on the inside. Later ones and 500 series screws on the outside.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595604
Sun Feb 01 2015 01:56 PM
Cameron Park,Ca.
Cameron Park,Ca.
The ID tags are different and another way to tell the two series apart with out opening the door. That is if you can read it on a unrestored pump.
The hose outlets were the same but there were 3/4 and 1 inch sizes. Als found a 90 degree one most were a 45 degree. There was also a safty shut off style.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595607
Sun Feb 01 2015 02:02 PM
Cameron Park,Ca.
Cameron Park,Ca.
The 300 series faces were flat and used a steel mounting pan. They were aluminum. I do have one flat porcelain set and seen one other set. The 500 used a one piece face with rolled sides. They came in aluminum and porcelain. The 546,566 and567 used both styles of faces.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595609
Sun Feb 01 2015 02:06 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here are picture of the twin parts. The twin is basically two single pumps joined together. The bases have a flat spot to join the and the reset is on the hose side. These pictures are from a 542.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595612
Sun Feb 01 2015 02:10 PM
Cameron Park,Ca.
Cameron Park,Ca.
Gas Pump Blue Book codes. On these goes by the letter in your seial number. If there is two letters it is the second letter.
J - 1938
K - 1939
L - 1940
M - 1941
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595616
Sun Feb 01 2015 02:15 PM
Cameron Park,Ca.
Cameron Park,Ca.
Interchangeable parts include:
top sheet metal
globe holder
access door
hose outlet ans bezel
sight glass assembly (diffferent on 546,566.567)
ad glass and door glass retainers
faces, even though they are different
reset handles
Feel free to post pictures. I will post my pumps ans a little 76,77 info later.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595638
Sun Feb 01 2015 03:25 PM
Parkersburg, WV 26101
Keystone Gas Man Offline
Thanks Matt, I have a 371..Keep it coming!
Re: POTM "pump of the month" Bennett Feb 2015 [Re: Keystone Gas Man] #595640
Sun Feb 01 2015 03:26 PM
Bardstown, KY USA
philmccauley Offline
Bardstown, KY USA
Good job Matt.
Thanks, Phil
Re: POTM "pump of the month" Bennett Feb 2015 [Re: philmccauley] #595695
Sun Feb 01 2015 07:05 PM
Cameron Park,Ca.
Cameron Park,Ca.
The Bennett 76 and 77 came in an early and later version with both versions having a two or four ad glass top. These were also sold with SSE 76, 77 ID tags (Service Station Equipment). They were made from 1935 to 1939. The early model has a external visi guage and a one piece casted face bezel with the trim part chrome plated. Some of the real early models had a cast iron top, the rest a pot metal top. The later model has a sight glass in the face with cut outs in the trim area and separate stainless trim that fit in place. The 76 is a computing pump with a Veeder Root and the 77 is a non-computing pump with a clock unit. The early model had a different reset handle the the later. These pumps also had east ans west coast light units like the 300 and 500 series. There was also a special face bezel made for Sohio. I do not have a lot of pictures of these pumps but do have an early and late model.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595696
Sun Feb 01 2015 07:08 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here are the faces
Here are the handles
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595699
Sun Feb 01 2015 07:16 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here is the east cast and west coast light units.
Here is a later 77 with four ad glass top.
Early 76 and visi gauge
Blue book dates, same as above
F 1935
G 1936
H 1937
J 1938
K 1939
Let`s see your pumps
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595702
Sun Feb 01 2015 07:24 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here are some of mine. I forgot to mention that the 300 and 500 series came with four, two, or no ad glass. The 546, 566, 567 came in two or no ad glass.
Re: POTM "pump of the month" Bennett Feb 2015 [Re: MATT ALVAREZ] #595703
Sun Feb 01 2015 07:29 PM
Cameron Park,Ca.
Cameron Park,Ca.
If anyone wants their pump posted and has trouble getting pictures on here you can email them to me and I will ad them. My email is in my profile.
Page 1 of 4 1 2 3 4
Page Time: 0.041s Queries: 14 (0.015s) Memory: 1.9332 MB (Peak: 2.1014 MB) Zlib disabled. Server Time: 2018-02-22 20:56:26 UTC
