Page 1 of 4 1 2 3 4
Anyone converted Wayne 70 to a Wayne 71 showcase? #594701
Tue Jan 27 2015 06:01 PM
Indiana
bagged1961 Offline OP
Indiana
Just curious if anyone has used the aftermarket Wayne 71 showcase parts to convert a Wayne 70 to a display pump? I noticed the bases the main piece that they do not produce.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #594702
Tue Jan 27 2015 06:03 PM
Devils Lake, ND---USA
K W FRITH Online content
K W FRITH  Online Content
I don't think it would be possible.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: K W FRITH] #594726
Tue Jan 27 2015 07:23 PM
Humble, TX
SKomatinsky Offline
SKomatinsky  Offline
Humble, TX
Could be done but you have to really be top notch with metal fabrication to pull it off. Craig said it was a pain to get an original aligned when putting back together, so I can only imagine how hard it is to fabricate
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: SKomatinsky] #594771
Wed Jan 28 2015 12:41 AM
St. Louis, MO, USA
Jack Sim Online content
Jack Sim  Online Content
St. Louis, MO, USA
Seriously, the 70 is about 24" wide, the 71 is about 36" wide. Enough said.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: Jack Sim] #594831
Wed Jan 28 2015 09:35 AM
Alabama, USA
Dale Stephens Offline
Alabama, USA
PM sent...
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: Dale Stephens] #594989
Wed Jan 28 2015 08:04 PM
Portland Oregon
Craig Osbeck Online content
Craig Osbeck  Online Content
Portland Oregon
It is difficult, but possible with the middle and bottom doors. Good metal body man can make that happen, but the top door would require metal to be taken off both sides in order to fit. Could be wrong also, but think the sight glass is different also.
If they could make a Wayne 50 then anything is possible.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #703997
Tue Feb 06 2018 06:13 PM
Indiana
Indiana
Finally progress on our wayne 70 to 71 showcase conversion. Got 1 door hinged and internal structure braced and upper panels are mounted. Been a slow process but making headway as of late.
[Linked Image]
[Linked Image]
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704006
Tue Feb 06 2018 08:26 PM
Portland Oregon
Portland Oregon
It is looking good. There is lots of time involved for sure but like anything else it can be done. With the reproduction doors you can fit the body to the doors verses the other way around. Filling in the base also I see. Looking forward to seeing the final product. Good luck with it.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704025
Wed Feb 07 2018 09:15 AM
South of St. Louis, MO USA
Oldgas Online cool
Oldgas  Online Cool
Looks like it is coming along nicely. A lot like doing custom fabrication on a chopped and channeled hot rod. Takes some skill and creativity to get it to come out right. Keep posting pictures as you go.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: Jack Sim] #704045
Wed Feb 07 2018 04:31 PM
Tacoma,Wash. USA
tjhvintage Offline
tjhvintage  Offline
Tacoma,Wash. USA
Nice metal work! You obviously have some great fabrication skills.
a.) looks like it may be possible
b.) it appears there's more to be said.
Member #163
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: tjhvintage] #704050
Wed Feb 07 2018 05:59 PM
Lodi, CA.
Signal Gas & Oil Offline
Lodi, CA.
The can't be done looks like might be done. I have a metal working guy does this kind of stuff all the time.Good job. Keep it up.
Ted Pam Ethyl & Polly Roach
Lodi CA.
209-210-8971
Looking for Signal, Hancock, Mohawk, Douglas, Gilmore and Richfield
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704051
Wed Feb 07 2018 06:07 PM
Duluth, MN U.S.A
Ryan Underthun Offline
Duluth, MN U.S.A
I dont think this would be all that difficult to do. The hardest parts needed are available through gas pump heaven. The gas manifold is the same as early 70's as well as the computer mounts ect. The hardest part would be making the electrical manifold for the showcase and fabricating the top. I would think that a base could be made pretty easy out of 2 and if done correctly I dont think you would be able to tell that it was not a factory 71 base.
visit my website for original gas pumps and parts
www.thepumpdump.com
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: Ryan Underthun] #704069
Wed Feb 07 2018 11:00 PM
Cleveland,Ohio U.S.A.
JimT Offline
JimT  Offline
The top might be kind of tough-no?
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: JimT] #704086
Thu Feb 08 2018 08:37 AM
Louisville, Kentucky
LOWright Offline
LOWright  Offline
I knew if it could be done, you guys could do it! Looks great! Watching....
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704116
Thu Feb 08 2018 06:41 PM
Alabama, USA
Alabama, USA
I did one of these about 4 years ago. To do the top, I cut 2 tops up and welded them together to form the wide top needed and as someone already mentioned, I cut 2 bases apart and welded them together to form the wide base. I'm just a flunky when it comes to welding and body work but it really turned out well. I'd post the pictures of it but I don't have them stored in my computer, only on my phone. If someone would post them I could sent them through a text message....Dale
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704215
Sat Feb 10 2018 05:45 AM
Indiana
Indiana
Thanks for all the kind words. Our pump won’t be an exact 100% true recreation but will be very close. You can look at it and know it’s a Wayne 71 but subtle differences. We are building it off of pictures, honestly we have never seen one in person.
Our biggest struggle is mounting the veeder root. Close to figuring out the slight glass manifold. Parts of this pump will be purely cosmetic to give the look of certain parts with our own mounts and adaptations.
Jim, we are going to use 2 tops to make 1 which is just cutting and welding. Don’t think it will be too bad but nothings been easy sir far.
Finally, BEST part of this whole build is the fact that my dad and I are doing it together.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704223
Sat Feb 10 2018 09:13 AM
Arizona
azjockey Offline
azjockey  Offline
Arizona
Great job on the wayne and can't wait to see it finished, but your right the fact you both get to work together is fantastic.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704226
Sat Feb 10 2018 09:37 AM
Michigan, Union Pier
Done4 Online content
Done4  Online Content
You and you dad are doing a great job. Thats what is so cool about our hobby that guys will take on a challenge like this. I personally never liked the 71 display case but what you are doing is very cool. Glen Thompson had a couple and always tried to talk me into buying one but could never get past how it looked. Thanks for the post.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: Done4] #704227
Sat Feb 10 2018 09:49 AM
JimT Offline
JimT  Offline
I really like the looks of them (even though they are a bit homely)and think they capture perfectly the feel of the time and of the locations where they were used. There certainly are "Better looking" display pumps. -probably just about all of them.lol Most of us cant afford or dont get lucky enough to chance into nice original display pumps but once or twice-if ever- in our collecting lifetimes. Especially now days.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: Dale Stephens] #704260
Sat Feb 10 2018 07:20 PM
Indiana
Indiana
Text me at765-432-6406 I’d like to see the pictures
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704280
Sun Feb 11 2018 09:06 AM
LOWright Offline
LOWright  Offline
Dale, Text them to me and i will post them...1-502-396-3435
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704363
Mon Feb 12 2018 09:54 AM
LOWright Offline
LOWright  Offline
Here's Dale's Pics...
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: LOWright] #704366
Mon Feb 12 2018 10:39 AM
JimT Offline
JimT  Offline
Wow. It came out really good Dale!
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704373
Mon Feb 12 2018 11:22 AM
St. Catharines ON Canada
J, Micieli Online content
J, Micieli  Online Content
Nice display!
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704376
Mon Feb 12 2018 11:33 AM
Laingsburg, Mi.
W
we're the other guys Offline
W
Laingsburg, Mi.
very very cool well done !
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: LOWright] #704442
Mon Feb 12 2018 05:35 PM
Alabama, USA
Alabama, USA
Thanks,guys, for the fine compliments. And a big THANK YOU to Owen for posting the pics for me.....Dale
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704446
Mon Feb 12 2018 06:25 PM
Peotone Illinois U.S.A
Bass Master Offline
Bass Master  Offline
Dale, You did an awesome job on that 71, Nice work!!
Brian
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704454
Mon Feb 12 2018 08:57 PM
Indiana
Indiana
Dale did a phenomenal job!
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704472
Tue Feb 13 2018 06:53 AM
Spring Valley,Illinois
pumpdoc Offline
pumpdoc  Offline
I have an original one and I hope when it is done it will look half as nice as Dale's...
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704521
Tue Feb 13 2018 07:25 PM
Alabama, USA
Alabama, USA
Thanks guys. It was a lot of hard work but the end result was worth all the sweat....Dale
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704660
Thu Feb 15 2018 06:00 PM
Indiana
Indiana
Top is cut and just sitting on the pump. Little more difficult than we thought but getting there....
[Linked Image]
[Linked Image]
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704670
Thu Feb 15 2018 08:48 PM
Oldgas Online cool
Oldgas  Online Cool
Looks great, Dale! Thanks for sending in the pics.
Lots of work, Seth, but I'm sure the end result will be worth it.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704720
Fri Feb 16 2018 06:26 PM
Indiana
Indiana
Sight glasses are mounted!
[Linked Image]
[Linked Image]
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704827
Sun Feb 18 2018 04:56 PM
Indiana
Indiana
Veeder root is mounted...starting to really look like a gas pump!
[Linked Image]6DB4B6B_zps2qj0xbws.jpg.html][Linked Image][/URL]
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704844
Sun Feb 18 2018 08:23 PM
JimT Offline
JimT  Offline
You guys are going to town.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704852
Sun Feb 18 2018 10:13 PM
Hays, Kansas
bsplichal95 Offline
bsplichal95  Offline
Hays, Kansas
Love those pumps. Great job.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705060
Wed Feb 21 2018 04:18 PM
Indiana
Indiana
Base is getting welded up...
[Linked Image]
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705070
Wed Feb 21 2018 07:02 PM
Indiana
Indiana
Base is finished!
[Linked Image]
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705076
Wed Feb 21 2018 08:47 PM
Cameron Park,Ca.
MATT ALVAREZ Online content
MATT ALVAREZ  Online Content
Cameron Park,Ca.
Looks good!! Is that an aluminum base? I had a Wayne 70 with an aluminum base in the past and thought it was unusual.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: MATT ALVAREZ] #705087
Thu Feb 22 2018 07:12 AM
Indiana
Indiana
Yeah it’s aluminum, I think they made aluminum and steel. We have another wayne 70 and it has aluminum base as well.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705519
Thu Mar 01 2018 07:52 PM
Indiana
Indiana
A little update: veeder root is mounted. Glass installed. Starting to look like a gas pump.
[Linked Image]
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705520
Thu Mar 01 2018 08:12 PM
Cameron Park,Ca.
Cameron Park,Ca.
Looks great!!! Looking forward to seeing you build the showcase area.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705563
Fri Mar 02 2018 10:42 AM
Denmark
Gas pump Dane Offline
Denmark
Very good work, I look forward to seeing pictures as the restorations goes on, and of the finished result
I really like the Wayne 71 model
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705598
Fri Mar 02 2018 07:52 PM
Indiana
Indiana
Inside showcase sheet metal is done. Still needs a few tweaks.
[Linked Image]
[Linked Image]
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705602
Fri Mar 02 2018 09:08 PM
Portland Oregon
Portland Oregon
Looking good, are you going to weld the top face sheetmetal to the door there ?
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705639
Sat Mar 03 2018 04:02 PM
Indiana
Indiana
Well, it is done. The next owner can finish the restoration. We just wanted to see if we could do it. Not 100% identical but pretty dang close.
[Linked Image]
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705647
Sat Mar 03 2018 06:47 PM
Missouri,USA
Rabbitman Offline
Rabbitman  Offline
Missouri,USA
Looks really good! I just picked up a Wayne 70 today that would be a prime candidate for this.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705657
Sat Mar 03 2018 09:19 PM
Cameron Park,Ca.
Cameron Park,Ca.
It came out nice, I should try and build one.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #705664
Sat Mar 03 2018 11:43 PM
Missouri,USA
Rabbitman Offline
Rabbitman  Offline
Missouri,USA
Wish you were closer Matt, we could get it all down if we built two!
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #706145
Mon Mar 12 2018 12:20 AM
Denmark
Denmark
Great job guys, please post some pictures of the work you've done inside the pump and also of the top plate if it's fit and finish done and welded
Page 1 of 4 1 2 3 4
Page Time: 0.053s Queries: 15 (0.012s) Memory: 2.1166 MB (Peak: 2.4850 MB) Zlib disabled. Server Time: 2019-02-21 04:14:25 UTC
