Page 1 of 5 1 2 3 4 5
#530494 Wed Apr 23 2014 11:34 PM
finally started construction on my island , pumps & light pole project. its only been in planning stages for 16 yrs... i've mentioned it in other posts, but decided to compile everything in one thread that i can update as progress moves along. besides the island, i also have one of the rectangular sinclair signs to restore & hang on the building behind the pumps (gilbarco 96c's) & a matching gilbarco short commercial/farm pump that will probably be stenciled as a "super flame" kerosene pump.
set the pumps & light pole spaced where i wanted them & assembled the main form for concrete:
built templates for the mounting bolts to be set in the concrete based on height of pump bases:
dug the trench & laid the conduit for electricals today. the 96c's dont have an access door on the side like other pumps, but i'll be fabricating one to give access to a main switch to turn everything on/off together. i'll make a bracket to fasten the box to the frame once its in position.
i didnt get any pics of the pumps before i started teardown, but both are pretty solid & skins/doors are straight.
only issue was one had ad glass, the other didnt.
took about two hrs to convert the non ad glass doors to ad glass versions. i used the window frames from the other pump for layout. cut/snip/weld...
i used strips cut from the extra section that was removed to make the edge pieces that curve in towards the glass. the trickiest part is the ad glass opening is 1/8" shallower than the window opening, so had to trim that edge down a bit. pump frames head out to the powdercoater tomorrow.
sellersrodshop #530499 Thu Apr 24 2014 12:39 AM
Great work done. ... can't wait to see it all done
Martin from OZ #530500 Thu Apr 24 2014 12:47 AM
Looking good, so far!!!
Dave GILL,
Dave's Garage #530501 Thu Apr 24 2014 02:22 AM
Wow! A lot of work!! But everything looking great!!
Steven C. #530508 Thu Apr 24 2014 05:06 AM
Just a thought but, your electrical access problem could be solved by simply hard wiring the pumps and putting a switch or timer inside the shop. That way, no access door would be needed. A simple inexpensive timer can be set up to light the pumps at a certain time and shut off at another? I've done a few of these and the timer works great. Another option is to use an electric eye at the pump but the pumps would remain on all night. Paul www.severngaspumps.com
gasmansgp #530518 Thu Apr 24 2014 05:57 AM
Looks good!
Ryan Underthun #530537 Thu Apr 24 2014 06:52 AM
On your way to a awesome island!
________________
Kurt
gasmansgp #530565 Thu Apr 24 2014 08:27 AM
i've kicked myself numerous times for not adding a box/switch for this inside when i wired the shop. the inside walls are the same type metal thats on the outside & to do it now, i would have to remove about 20ft of cabinets, countertop, sewing machine & possibly drop the t.v. just to get the walls bare to remove the metal to do something. i have seriously considered looping a timer into the system, but still want a main switch for times i dont want it on.
sellersrodshop #530607 Thu Apr 24 2014 12:46 PM
Looks great so far
bsplichal95 #530610 Thu Apr 24 2014 01:09 PM
main switch + a photo eye
thats the way I prefer them.
since this is for more than one piece, i would mount the photo eye directly to the switch casing. the eyes are just as cheap as a timer and you don't have to reset them all the time in case of a power outage or time change. would only cost about $8-9 to add this to your setup and get rid of the timers idea.
BryceG #530611 Thu Apr 24 2014 01:20 PM
There are also astronomical timers that automatically adjust for the date..... I set my pumps to come on for an hour at dusk.
More expensive - but you just need one. Just another option.
Ray
rbonitz #530620 Thu Apr 24 2014 02:29 PM
I also use an astronomical timer and have been very pleased with it. It turns on my sign lights at dusk and goes off at 9:45 every night. The timers also have a manual switch if I ever want to turn it on earlier or have it stay on later.
TheGriffin #530643 Thu Apr 24 2014 03:36 PM
N
N
really nice!!
you know your pole will look great. Just put one up.
Nubbers123 #530693 Thu Apr 24 2014 06:12 PM
Looks good. Nice work on the door.
JimT #530727 Thu Apr 24 2014 08:55 PM
thanks for all the kind words/advice. i'm really excited about finally getting this going after so many years in the planning. reality has set in about how short life really is after finding out two guys i know (my age) passed away lately. one from cancer, the other from a massive heart attack. gotta make the time to do something for myself every now & then instead of thinking, "i'll get to it later/someday"...
