Page 2 of 3 1 2 3
The repo is powder coated and dated at the bottom of the neck. The date is stamped into the metal. Also there is not a sleeve bearing in the shaft like in the real one. I own a real one {pictured} and have had the repo. I was impressed by the quality of the repro. It even felt to have the same weight as the real one.
The real ones came in two sizes. Like the one I have and a smaller version. I gave close to a grand for mine but it has a great weathered patina that I love.
Do you know, what is the date on the reproduction?
Where is the bearing on the original? Is there only one bearing inside the tube?
Email :john@barnquiltshop.com
"The Fun Is In The Hunt"
Web site: www.barquiltshop.com/
I don't remember what the date was on the repo. It had a number month and a two number year. I believe the year was 10 but not sure.
On the original if you stuck your small finger in the shaft, you could feel the sleeve bearing. There are two small indentations on the exterior of the shaft to hold the bearing in place. It is about 3/4 in. from the base. The bearing is about an inch and a half long.
I think maybe the reproduction was one of mine. They were EXACT reproductions of the originals. We powder coated them and date stamped them so they would be harder to pawn off as originals.
As for originals, I have personally owned five of them. Two came directly from Pontiac dealerships. One was new old stock and in the original box and never been used. None of them had any bearings in the pipe. They were designed to slip over the mounting pipe.
Maybe the bearing was added buy the previous owner?
Now if you think about it, if you put a bearing inside the pipe at the bottom, you would most likely need another at the top of the pipe to provide stability and prevent wobble. That would also make the mounting pipe much smaller and decrease wind load strength. There really is no reason to use anything but the pipe inside the pipe. Either way they are really cool!
I was wondering why you were asking because I thought that you had made the repro's . You did a really nice job on them. I had purchased two of them. I picked one up for a friend who was going to make one for himself using mine as pattern and sold the other to another friend. Both friends were very happy with them. I have my real one hanging on a bedroom wall.
New year....any new leads? Still looking smile
The quest continues.....spring is coming - barns being cleared. Any leads - still looking for a good original Pontiac weathervane
Still looking for a Pontiac weathervane in original condition smile
Looking for an original Pontiac weathervane - original surface - no overpaint, no repros. Will pick up in New York, Ohio, or Michigan.
Anyone happen to obtain a decent one over the summer that they are willing to sell? Thanks smile
Saw one of those at an antique mall a few months ago. The place was located in Benton pa.
This is a link to their website
http://www.bakeryantiques.com/index.php
They are about an hour from me. If it was closer I would stop by and check it out for you. Good luck!
Always looking for more pumps, meters and signs.
Some say it is a problem, I say it is a solution
Thank you Scott - I'll give a call!
There is one currently listed on e-Bay for sale 191483850423.
Dave GILL,
I'm still in search of an excellent original Pontiac Weathervane. smile Will travel within New York, Michigan, Penn, Ohio, Ontario for pickup.
I believe Jeremy just got one, check with him: Profile here
Page 2 of 3 1 2 3
