#427141
Tue Jul 02 2013 10:23 AM
Posts: 2,772 Likes: 3
Posts: 2,772 Likes: 3 |
Bought this the first week in March. Took this long to get it home. Can't wait to tear into it, but will have to wait till next week. Was found 30 years ago in the desert in what is now a portion of Mesa AZ. Sheet metal has two little dents and no rust. Larry
Update: Wife daughter and grandkids went to the Natural History Museum so,,,, tore into it. Now if I can figure out how to remove hose reels. Another day...
Posts: 1,841 |
This is 2nd best, 1st is Visiting w/ Family
Cool! At that rate you should have it ready to deliver to me at Iowa?
Posts: 2,545 |
That spring looks like a widow maker! Very cool!
Scott Wright
Posts: 4,880 Likes: 50
Posts: 4,880 Likes: 50 |
I remember a few months back someone posted pics of one of these all restored. It was a beautiful piece!! I had never seen one before. Very Very cool piece!!! Good luck with it!!!
Got the hose reels out and cleaned up. Thanks to a phone call from Gaspumpfrank. Never talked to him before but he called and walked me through how to get them out. Thanks Frank
Edited: Thought I would add the 'how to' for getting the reels out. On the top drum (and its actually a brake drum with shoes) you can see in the pic a 'tab'. There is a screw that goes through the skins into this tab. Once its removed, simply turn the drum clockwise and it will lower until you can tip the reel out!
HHhhmmmm??? I have one that I haven't started on yet! I'm going to have to pay attention here. Please include all details and lots of pics!
A few more parts cleaned up. Larger parts/skins will have to go out to a sand blaster. Need to find someone that will chrome plate pot metal. Might give the guy in Omaha a call.
Larry
Posts: 275 Likes: 16
Posts: 275 Likes: 16 |
Since you are in Colorado, there is a place in Yuma called Quality Plating that does pot metal. They did some parts for me and they did a really good job. They were pretty fast and were pretty reasonably priced.
I will call them Monday. Thanks
Parts are back from the powder coater!!! Now to start assembly..
Larry
Rollers and handles are back from chroming!
Larry
Looking good! Keep those pictures coming!
Posts: 4,160 |
Wowsers Larry..thats coming out awesome
Posts: 166 |
Trial fitting the head.
Waiting to get some hose then I can put more together
Larry
Posts: 1,452 |
Looks great so far, keep the pix coming
Hope ya' all are not bored with this. Got My hoses made locally and got them this A.M.. Each reel has a hose inside itself plus whatever you put on the reels. Also need hose to take air into the meter, then calibrated air down to the hose reel. Not to mention a line that supplies water to that reel. Not a big deal. The problem was fitting the reels back in the housing. Fought that way too long... in and out, in and out.
""Islander tip if you restore one: You have to run the reel up the worm gear one full turn before putting the reels back in, or you will drive yourself crazy as to why they won't fit without hitting the stop.""
A couple pics along the way.
Car show tomorrow. Will wrap this up on Sunday
Staring to run lines. Still need to run the water line to top reel.
Larry
Posts: 1,998 Likes: 4
Posts: 1,998 Likes: 4 |
Looks great Larry! Love it! Let me know when you want to start on these of mine. Ill swing em by!
Posts: 1,192 |
Awesome! Very nice Meter.Thanks for the post.
Looking great! Almost done...looks like all the hard work is done.
Sitting' at a car show in the shade! You are right about the hard work Dave. Had those reels in and out a minimum of ten times yesterday. Now I know how to do it.
Larry
The final bits of work are fighting me. Thought I would show the restored tags. One on the head the other on the islander itself. I always try to restore tags.
Larry
Tell us about restoring the tags! I'm always scared to try for fear of ruining what I do have!
Posts: 1,391 Likes: 4
Posts: 1,391 Likes: 4 |
That's looks very nice ,you did a great job on it.
Posts: 19,470 Likes: 1022
Posts: 19,470 Likes: 1022 |
what a difference, bet you'll be glad when this project is over with- superb results..
Posts: 166 |
I am with Kevin,How did you make those tags look so nice? Perfect Larry!!
I am with Kevin,How did you make those tags look so nice? Perfect Larry!! give us a little school'en on the tags? or a address where to send them to be re-done- I have one that needs re-done..
Tell us about restoring the tags! I'm always scared to try for fear of ruining what I do have! I will try to explain the I.D. Tag restore process. Pretty simple. The tag you start with has to be perfectly straight. Any dents or bends you try to correct will show. I.D. tags have what I will call 'relief'---raised letters and numbers. A good candidate for restoring, the relief can be felt with your fingers. The Tokheim 39 and 300 tags are poor. Some tags are better than others. You can completely strip the tag if it has lots of paint from numerous paint jobs. But a good as found pump tag can generally just be sanded down on a very flat surface until the raised letters and numbers are shiny clean. I don't worry about the old black paint in the back ground.I then spray with gloss black from a rattle can. Let it dry very well. Then, again on a very smooth surface, wet sand it down with 320 or what ever you have thats not too rough. Go slow and keep looking at it. When the high spots are shiny, you're done. Don't worry, the back ground black with not look great. Then I shoot it with whatever I have in clear. That will bring the back ground back to a nice looking finish. They are not perfect and that adds to your project I believe. Good Luck Larry
Posts: 166 |
Larry you should do this service,Because you have an eye for detail, And I would love to be youre first customer!!
Its a wrap! Has been alot of fun. Now to the Tokheim 34.
Thanks Larry
Posts: 658 Likes: 3
Posts: 658 Likes: 3 |
Posts: 24 Likes: 5
Posts: 24 Likes: 5 |
I just stumbled upon this thread...WOW! Nice work!
