Page 3 of 3 1 2 3
Tunk-Z28 #454880 Mon Aug 12 2013 03:17 PM
Originally Posted By: Tunk-Z28
I am with Kevin,How did you make those tags look so nice? Perfect Larry!!
give us a little school'en on the tags? or a address where to send
them to be re-done-
I have one that needs re-done.. cool
K W FRITH #454923 Mon Aug 12 2013 04:44 PM
st.rod Offline OP
Originally Posted By: K W FRITH
Tell us about restoring the tags! I'm always scared to try for fear of ruining what I do have!
I will try to explain the I.D. Tag restore process. Pretty simple.
The tag you start with has to be perfectly straight. Any dents or bends you try to correct will show. I.D. tags have what I will call 'relief'---raised letters and numbers. A good candidate for restoring, the relief can be felt with your fingers. The Tokheim 39 and 300 tags are poor. Some tags are better than others.
You can completely strip the tag if it has lots of paint from numerous paint jobs. But a good as found pump tag can generally just be sanded down on a very flat surface until the raised letters and numbers are shiny clean. I don't worry about the old black paint in the back ground.I then spray with gloss black from a rattle can. Let it dry very well. Then, again on a very smooth surface, wet sand it down with 320 or what ever you have thats not too rough. Go slow and keep looking at it. When the high spots are shiny, you're done. Don't worry, the back ground black with not look great. Then I shoot it with whatever I have in clear. That will bring the back ground back to a nice looking finish. They are not perfect and that adds to your project I believe. Good Luck
Larry
st.rod #454929 Mon Aug 12 2013 05:12 PM
Larry you should do this service,Because you have an eye for detail, And I would love to be youre first customer!!
Tunk-Z28 #455448 Wed Aug 14 2013 12:31 PM
st.rod Offline OP
Its a wrap!
Has been alot of fun. Now to the Tokheim 34.
Thanks Larry
st.rod #455472 Wed Aug 14 2013 02:52 PM
That looks awesome!
Dave GILL,
Great Job Larry!
Ric
DuceCpe #532246 Thu May 01 2014 09:32 AM
I just stumbled upon this thread...WOW! Nice work!
Page 3 of 3 1 2 3
