Gas globe guy #384215 Mon Jan 07 2013 04:09 PM
L
L
Noah I take the face plate off and cut the pipe as close as I can,with a saws all. Then after you pull the computer you can get to it to remove the fittings from the top.
Loyd Pierce #384219 Mon Jan 07 2013 04:13 PM
ok, I had to cut of the piece of metal that turned the gears in the computer, I hope that was a good decision. I will try and cut the pipes out tomorrow.
Noah
Gas globe guy #384259 Mon Jan 07 2013 06:23 PM
F
F
If you are talking about the coupling from the pump up into the computer, yes, it is fine to cut. As many members as there are from your area, why don't you try to find one close enough to give you some assistance (maybe a Saturday or two). It could be a great bartering situation for them, and a great learning opportunity for you. Some more experienced input might help keep you from mistakes or getting frustrated. Fun to see your enthusiasm!
Flatland #384260 Mon Jan 07 2013 06:25 PM
I will look for some people close to me, I will post an add.
Noah
Gas globe guy #384405 Tue Jan 08 2013 11:16 AM
here are some pics of my pumps. I don't have a pic of the top, but I will get one later. How does the electrical work? The pump in the first pics, has the really bad rust. I am restoring the small pump first, and then the big one. I am not sure if I should take out the part that is in the last pic.
Noah
Gas globe guy #384407 Tue Jan 08 2013 11:19 AM
I gutted this little guy, and now I am restoring it to be a marathon. I can't wait to finish it.
Noah
Gas globe guy #384422 Tue Jan 08 2013 12:29 PM
Originally Posted By: Gas sign guy
here are some pics of my pumps. How does the electrical work?
Noah
Noah,
You look like you have a good start. The electrical has to be all re-wired you can get the parts you need at a local hardware store. You will have to remove the whole light manifold and there should be a switch (junction box) that is on the conduit. This would be an on/off switch. I would suggest you redo all the wireing you don't have to but you run the risk of faulty electrical otherwise. If I can figure it out I am sure anyone can. I'll post some pictures later to try to help.
- Jacob -
Email: jake5246@hotmail.com
Cell 507-259-2601
bowserman #384444 Tue Jan 08 2013 02:13 PM
Noah looking good!!! Looks like a lot of work! Keep at it and keep us posted!!
Are you restoring this to make it fully functional again or is it just cosmetic? What do must people do?
Steven C. #384446 Tue Jan 08 2013 02:18 PM
It would be a pain to make the pumps work. And yes, it is allot of work, I got the little pump gutted in about 30 min. I am going to try and gut the big pump right now, I will post pics and keep all ya'll posted. I am just going to display them. I think most of the people that do pumps just use them for display. Thanks for all the help.
Noah
Gas globe guy #384850 Thu Jan 10 2013 10:36 AM
I am going to pause on my big pump. I will not be able to gut the big one for awhile. I will keep you guys posted on the little one and when I get started again on the big one.
Noah
Gas globe guy #413845 Fri May 03 2013 08:27 AM
I got one of the side doors off the gilbarco 996. Now, I need to get the other door off and then gut it. I will post pictures tomorrow. I will let you guys know when I get the next door off. And my uncle came over and helped me get the top off. It is looking good so far.
Gas globe guy #414203 Sun May 05 2013 02:24 PM
Looks like you are off to a great start Noah . If you need any parts for the red 996 I might be able to help. I did not see your doors or hinges but just a tip, you need to test fit those doors and hinges and if they do fit mark them to the correct side and door. If the doors when closed don't have equal and even gaps or have alignment issues like binding address this before you go any further . If those doors have ever had a pry bar put on them and the hinges were froze the hinges most likely will be stretched and sprung and have lost their original s shape curvature and can be a real headache ,as they are not reproduced to my knowledge , I know this because this happened to the 996 I restored and I had to heat and bend on them in a vise then reassemble this disassemble for two weekends until I got them right . And it wasn't fun. Just trying to save you some grief ,Keep us posted.
47reo-travis #414205 Sun May 05 2013 02:28 PM
Noah disregard , I was incorrect after I posted I realized this one has the screw in the top to release door my mistake , I'll have you all screwed up !
