#20779
Sat Oct 11 2008 03:02 PM
Posts: 1,663 Likes: 25
Posts: 1,663 Likes: 25 |
anyone have any sugestions on how to get paint off of a painted quaker state sign?? tried bug and tar romover without much luck. any sugestions?? thanks chris
#20780
Sat Oct 11 2008 05:32 PM
WHAT KIND OF PAINT ARE YOU TALKING ABOUT? BRUSHED ON LATEX? SPRAYED ON POLY? IF IT'S BRUSHED ON LATEX YOU MIGHT BE ABLE TO PICK IT OFF CAREFULLY WITH A SOMEWHAT DULL SINGLE EDGE RAZOR BLADE. HOW ABOUT GOO-GONE? IF IT'S BEEN SPRAY PAINTED, I'M AT A LOSS ON A FIX FOR THAT SITUATION. I'D LIKE TO KNOW A RESULT FOR THAT MYSELF. IF YOU HAVE GOO-GONE AND IT LISTS LATEX PAINT YOU MIGHT WANT TO TRY IT IN AN INCONSPICUOUS PLACE FIRST. YOU HAVE TO FIGURE THE SIGN ITSELF IS MOST LIKELY A POLY PAINT AND MAY'VE EVEN BEEN BAKED ON AT THE FACTORY? KEEP US POSTED ON YOUR PERSONAL ATTEMPTS! ~DOC
Sat Oct 11 2008 09:05 PM
it is brushed on, heavy coat of black on a quaker state tombstone sign. will try goo gone. thanks chris
#20782
Sun Oct 12 2008 06:31 AM
I have heard vegetable oil will raise the painted on paint. I have not tryed it so I dont know if it would work or not.
#20783
Sun Oct 12 2008 09:24 AM
CHRIS, ACTUALLY THE PRODUCT IS ACLLED "GOOF OFF!" SOUNDS LIKE GOO-GONE BUT ISN'T THE SAME. I JUST FOUND MY OWN CAN OF "GOOF OFF" WHILE LOOKING FOR SOMETHING ELSE AND THIS IS THE PRODUCT THAT REMOVES DRIED LATEX PAINT....NOT GOO-GONE. HOEP YOU READ THIS BEFORE YOU WASTE MONEY AND TIME.
~DOC
Sun Oct 12 2008 10:05 AM
Posts: 102 |
There is another product called Oops. But they recently changed the formula and it is stronger. We use it a work to remove printed logos from plastic parts. After the change it now attacks the plastic. I am not sure why it was changed but we have had problems like this before. So watch the can for things like "Improved Formula". Even if you have used the product before.
#20785
Sun Oct 12 2008 07:36 PM
Posts: 14 |
I would try it very carefully but we used to use dow oven cleaner to remove painted lettering on trucks. If the top layer is a softer than the original sighn finish it may work. This may be a last resort Phoneman
#20786
Mon Oct 13 2008 04:22 PM
Posts: 1,749 |
Uh, you might want to go to you're local hobby shop and ask them for some Polly-S Paint remover. This product will remove decals from plastics and not harm the plastis either. I do modeling and beleive mre I screw up paint jobs all the time . I would try this in an area thats not critical either. I also use CHEAP brake fluid too. however , this can reallya ttcck all paint quickly too, so be careful here.
see ya on the road folks !
#20787
Mon Oct 13 2008 04:53 PM
Posts: 79 |
Friend of mine found a sign painted over and he took FAST ORANGE hand cleaner, and worked it over with that. Hand cleaner was a little porous and had some citrus in it.
Posts: 1,078 |
Sorry to bring up an old thread Chris, but what did you use and what was the result?
tried everything except the goo gone or gunk gone whichever it is called, with not much luck at all. so i put it up until somone comes up with an easiser fix to my problem. not a rare sign, but i thought i woul try and get it cleaned up anyway. chris
Posts: 1,187 |
Carburator cleaner works pretty good.
Posts: 1,078 |
Bringing it back from the dead.....so Chris did you get it off, and if so, how?
sign still has paint on it, no luck. chris
Posts: 838 Likes: 11
Posts: 838 Likes: 11 |
Easy Off oven cleaner. They have two kinds. I use the one with the harmful vapors.
Posts: 558 Likes: 2
Posts: 558 Likes: 2 |
Hi. Over the summer I stripped a painted painted Atlantic curb sign using water, dulled single edge razor blade and course rubbing compound. Put the water on and give it a couple of minutes, then slowly work a single small area. Sometimes it gets stubborn which case I used a little rubbing compound to thin the area which helps get the process going again. Don't dig with the razor or pick at it, just slide it as the water is a lubricant so keeping it fairly wet helps. In my case the first bottom layers were older house paint and the top coat was a rubberized latex. See before and after pictures at BOTW: "BUYS OF THE WEEK!" - OCT 12TH - OCT 18TH. John
Be care full using GOOF OFF, it will take baked on paint off. db
Posts: 1,078 |
Mine is a painted sign on thin steel with spray paint in a small area.
Posts: 4 |
Hi I am new to this sight. And i was reading your request and i had the same problem with a goodyear sign . I tried everything i could think of and nothing worked.So finally i diluted automotive paint stripper with water and used that. And it worked great, but you have to work fast and keep rinsing with water and reappling.Good luck John.
John Paschen
Posts: 45 |
I read in the paper this morning that Martha Stewart reccomended alcohol to remove latex paint from wood floors. Might be worth a try...
Frank 1956 Chevrolet 210 Delray Sedan 1963 VW Type 1 with 1600cc; slammed 1965 IHC with SBC and Turbo 350 19?? Tokheim 300
