Posts: 5,979 Likes: 24
Posts: 5,979 Likes: 24 |
Joe, That computer is mine, sorry I did not know what not to leave on there. Please let me know how low to get so that you can kick me !! Let me know how much you need. Thanks Craig
Posts: 12 |
do you know whare i can find a metal shrowed for my veeder and is that required to mount add glass on a Neptune L1 Gas Pump?
Tony Garza
Sheet metal is just a dust cover, has nothing to do w/ ad glass.
Posts: 118 |
how do i get the computer out to have it re-build by you? i'm a rookie and this is my first pump.
I have regular sheet metal but not like what you are describing. Some computers can be tricky to get out after unbolting. If you ship it pack it well or it will get damaged, double box, UPRIGHT. If it lays on it's side it WILL get damaged. If you don't feel comfortable dropping it from 3', pack it better. These things are HEAVY and are made of soft metal. Thanks Joe
Build a wooden crate and bolt it to the bottom. Helps if it has a handle on the top also. By the way, Thanks Joe it looks great.
I have been rebuilding computers for 25 yrs now. I have seen certain "trends" in the biz. I am starting to see more flat wheel computers come in. Having flat wheels, means "older" computers. Older computers, means more wear & tear, more rust, more damages from mice, water, etc....but NOT ALWAYS. Mouse nests and mouse poop in the Variator can get into the cone gear teeth, and total disassembly and sandblasting is the only way to get it clean. Rust can be an issue also.
CONDITION will be the major factor.
If you have a normal used unit, rebuilds start @ $200.00. If the Variator or Head have to be disassembled due to rust or mice, they will be sandblasted, painted and re-assembled. In doing so there will be a $50.00 charge for the Variator and $50.00 for the head. Sometimes the Head needs disassembly and not the Variator. Sometimes the Variator needs disassembly and not the Head. Sometimes both Head and Variator need disassembly. MOST computers do not have to be fully diassembled, only the ones w/ "ISSUES" will need to have these steps taken.
Thanks to you all for your business over these 25 years. Joe Yocom
Posts: 297 |
What is the "HEAD" and what is the "VARIATOR" Thank You Don
Posts: 297 |
The HEAD (top) is just a counter w/ reset capabilities. The VARIATOR (bottom) does the calculations.
Posts: 8 |
I am just getting into rebuilding gas pumps, have 1 Tokheim 300, 3 tokheim 39's, 1 wayne 70. All need the computers rebuilt, Cost? where to send them? All at the same time? One at a time? etc, etc, Thanks for your time. Richard
Richard-- contact Joe thru his email---jkyocom@bellsouth.net He's the MAN for rebuilds and can answer all your questions.
I don't think he's on here reading these pages every day.
