#176040
Sat Feb 20 2010 10:57 AM
Posts: 1,627 |
I have a pair of original 15 inch Red Crown lens-- What type globe holder would these fit in to- I tried a 15 inch with snap rings -but the lens was too big -- Tom
Tom these would of went into a 15in medal body. Was the globe body original or repo that you tried to use?
Posts: 362 |
We had the same trouble...we tried fitting them on a 15" low profile and the wouldn't work the got a 15" high profile and they fit. Both bodies we used were original. Jerry
Thats odd I am going to watch this one & see what we come up with!!
Posts: 1,627 |
It was a repo body I tried it on--
Posts: 2,242 |
I've heard of a lot of people having problems with lenses fitting on repro bodies (bodies being too small). I believe repro lenses are even smaller to compensate. If you get an original body, you'd probably have better luck. I have also heard that high profile and low profile bodies are a little different size as well. I guess you could say that a 15" lens is not always a 15" lens...
Posts: 1,627 |
Thanks for the info I will try that--
Posts: 2,242 |
BTW, according to the globe book, this should be on a red High Profile body.
Good luck, Wes
THAT'S OKAY, I'VE BEEN HAVING ISSUES WITH EVEN PLASTIC 2PC CAPCO BODIES LATELY. SEEMS THE LENSES DON'T GO INTO THE GROOVE AT ALL AND THEN THE TOP SCREW DOESN'T CLOSE UP THE 2 HALVES SNUGLY!
Posts: 2,242 |
Doc,
What lenses are you putting in there? Maybe they're the thicker ones for a glass body? Those never fit in a Capco very easily (or very safely).
Posts: 858 |
I've been having the same problem with repop 15" lenses on an original low profile body. The lenses are still very rare, I think there is only 1 or two known sets of originals and 15 sets of repops so the snap rings are really terrifying me. I think I'm going to go with clear silicone and calling it a day.
WES, MY INVADER LENSES (MADE BY T-WAY) HAVE BEEN GIVING ME TROUBLE IN THE CAPCO LENSES. THE GROOVE LIP INSIDE THE PLASTIC CAPCO BODY APPEARS TO BE TOO UP AND DOWN AND NOT ON AN ANGLE OR THE GROOVE JUST NOT WIDE ENOUGH TO LET THE LENS SLIP IN NICELY. THEY ARE CAPCO'S.
Posts: 2,242 |
I see what you mean. Perhaps the lenses have more curvature than original Capco lenses?
BOUGHT A BUNCH OF CHEAP CAPCO'S FROM THE OTHER CHANNEL LAST YEAR. MAYBE I SHOULD JUST BUY A RANDOM ONE FROM SOMEBODY ELSE AND SEE IF IT WORKS BETTER???
Get rid of notch tabs in Crapco body. What do you have to loose ?
