#161304
Sun Nov 22 2009 07:58 PM
Posts: 1,452 |
Hi guy's, does anyone know of a good paint and body man in the Colorado area? I am in Arvada, but I can travel if necessary. Thanks Lee
Posts: 391 |
Now you know Lee we will want pictures
Posts: 1,452 |
I am restoring a couple pumps, they will need minor body work and then everything painted. Sometime after the first of the year. The parts would be sand blasted,and everything would be taken apart. If possible I would like to emboss a couple of the new skins. If I new it would work, I would cut out a pattern of the origional embossing and redo it on a new skin. "Tokheim 34" prety simple pattern, i just wonder if you would get warpage. Or maybe cut out patern and tack weld on skins. If this can not be done just simple body and paint on. Any help would be appreciated, thanks for the responce.
Would be glad to post some pictures when done. Thanks Lee
Posts: 649 |
Hi Lee,
Your concern about panel warpage from sandblastihg is well founded. Personally, I had so much problem with it that I haven't done it in years. See what some of the other guy's think; maybe I just had bad luck. Is that a 34 you are working on?
Posts: 391 |
Its true if done wrong sandblasting can really hurt a panel. But if you have someone who knows how to do it and uses the right media, then it can't be beat for getting a panel clean and ready for body work.
Lee I sent you a PM
Posts: 1,452 |
Yes its a Tokheim 34 I'm working on. I was also concerned about warpage when trying to re emboss it. Thanks Lee
Posts: 391 |
Ok, Here's what I ended up with after a bit of work.
Posts: 366 |
That looks good. How did you end up with that, did you make a die to stamp it? I have a 34 and was thinking of making something like that or adding a second layer to my repro skins. tony
Posts: 4,024 Likes: 135
Posts: 4,024 Likes: 135 |
That stamping does look good. I have been banging, hammering and heat shrinking on my original doors. Alot of work just to save that little design. One door is in primer ready for paint and the other has the metal work done and ready for body filler.
That is really cool!! Very nice work
Posts: 538 |
Wow that looks good! Be carefull you will have fleet of new skins showing up to be done. HA HA. Nice work.
Posts: 391 |
A little more work on my dies and I will be ready to stamp out as many panels as you guys need done. Here is another one I was playing with...
Posts: 1,452 |
That would look sharp on an old street rod pump.....
Here is the one that was mudded before primer.
Posts: 366 |
Jeremy, how's things coming on the dies for the Tok 34 panel emblems? If you are going to try make some to sell, I'd be interested in a set. Thanks, Tony
