#155819
Tue Oct 13 2009 07:24 AM
Posts: 24 |
I have a large Porcelain Cities Service sign that has been shot with a shotgun. What is the best way to repair it? I want to do it myself. Thanks, Jimmy
Posts: 3,550 Likes: 20
Posts: 3,550 Likes: 20 |
If you could post a picture it would give some folks here and idea as to how to help.
Posts: 3,359 |
If you could post a picture it would give some folks here and idea as to how to help. That would probably be a good idea.
I CAN'T WAIT TO SEE THIS ONE.
EMAIL ME THE PICTURE(S) OF THE PATIENT IN NEED OF A FACE-LEFT! LOL! docshots@yahoo.com
.....ERRRR, I MEAN COSMETIC SURGERY!
I THINK WHAT YOU SHOULD DO FIRST IS SCRUB THE RUST STAINS OFF FROM AROUND EACH POCK MARK. THOSE DEF ARE HI-LIGHTING EACH CHIP. I PERSONALLY HAVE FOUND THAT USING SOFT SCRUB WITH BLEACH AND A VERY FINE NO SCRATCH PAD OR 0000 (FOUR ZERO) STEEL WOOL USUALLY DOES THE TRICK. I WOULD DO A TEST AREA FIRST AND SEE HOW IT GOES. SOFT SCRUB WITH BLEACH IS A THICK CREAMY SUBSTANCE THAT CAN BE SMEARED OUT HEAVILY AND LEFT OVERNIGHT WITH THE SIGN IN A FLAT POSITION. WITH A WET NO SCRATCH PAD OR THE STEEL WOOL BUFF THE RUST STAINS...SEE HOW IT GOES WITH LIGHT PRESSURE AND ADD MORE PRESSURE WHEN NEEDED. SOMETIMES IT'S NOT EASY AND WITH THIS MANY SPOTS ON THAT MANY CHIPS IT'S GONNA TAKE SOME TIME...BE PATIENT. OTHER GUYS CLAIM THAT BAR KEEPS FRIEND, OVEN CLEANER AND TOILET BOWL CLEANER WORKS AS WELL. REMEMBER TO USE RUBBER GLOVES TO PROTECT YOUR SKIN. OVEN OR TOILET BOWL CLEANERS SHOULD BE USED IN A WELL VENTILATED AREA. IF YOU WANNA KNOW HOW I WOULD TACKLE SHOULD A LARGE TEDIOUS JOB? I'D PROBABLY USE SPOT PUDDY FROM A TUBE AND A PLASTIC SPREADER. WHEN THAT WAS DRY I'D USE A SOFT CLOTH OR DECENT SHOP PAPER TOWEL AND SOME LACQUER THINNER TO WIPE OFF EXCESS SPOT PUD SO THAT IT IS JUST FILLING THE HOLES AND NOT THE GOOD AREA AROUND THE CHIP. YOU COULD THEN GET YOURSELF A SMALL TOUCH UP BRUSH AND SOME OFF WHITE PAINT. VERY RARELY DOES AN OLD WEATHERED SIGN LIKE YOURS STILL HAVE THAT ORIGINAL WHITEY WHITE COLOR. YOU WILL HAVE TO DETERMINE WHAT TINT THE WHITE WILL NEED BY MIXING AND TESTING A FEW SAMPLES. AS FOR THE LETTERS, AGAIN YOU WILL HAVE TO MIX AND TEST A FEW TONES OF GREEN. WHAT'S DIFFICULT THEN MIXING AND TESTING OIL BASED POLY PAINTS IF THAT THEY USUALLY DRY A BIT DARKER THAN THEY GO ON. SO IF YOU HAVE A SLIGHTLY LIGHTER GREEN THAT WHAT IS ON THE SIGN...YOU'LL PROBABLY END UP WITH SOMETHING PRETTY CLOSE WHEN IT DRIES IN A FEW HOURS. I'D LIKE TO SEE HOW THIS COMES OUT AS YOU GO ALONG WITH YOUR PROJECT. FEEL FREE TO FORWARD ANY SHOTS TO ME AS YOU PROGRESS.
Posts: 311 |
Hi Jimmy. Im a new guy on this block and have had a few postings here and always picking up bits of info and sometimes able to pass a few on. First the dirtbags used two different shotgun loads. larger holes, a duck load and the smaller holes a quail load, fired after the other. Thats my CSI for the day. Anyway too bad you couldnt try to hammer and dolly the bad ones cause Im sure they are jagged. Once filled with what ever filler you choose. (I like the autobody type) wet sand with 400 and 600 grit. I do air brushing on my pumps and things and it makes it easy to fog or blend into the good areas. There are some good "water born" paints out there in hobby shops. they come in small bottles and tinting is easy since your are working with green also. It will never look good up close but will pass once on the wall. I saved a Signal sign this way and after applying my artistic ability to it no collector wanted it. critics said it looked good considering it had 12 .45 holes in it...................Roger
Posts: 639 |
How about extra holes? nail and bullet..... tt
That sign lookspretty good. If it were mine I would clean the rust stains and hang it up.
Posts: 979 Likes: 1
Posts: 979 Likes: 1 |
That sign lookspretty good. If it were mine I would clean the rust stains and hang it up. I think Matt is right. That type Cities sign is not that expensive anyway. Clean it and hang it. A better displayable one will come along for a very reasonable price...Dale
Posts: 913 |
That sign lookspretty good. If it were mine I would clean the rust stains and hang it up. I think Matt is right. That type Cities sign is not that expensive anyway. Clean it and hang it. A better displayable one will come along for a very reasonable price...Dale I "third" that opinion.
FORGOT TO MENTION I BOUGHT THE SAME STYLE SIGN AT MASON-DIXON LAST SPRING FOR $80 AND JUST HUNG IT UP AS IS.
Posts: 858 |
Yeah I'd clean it in the method Doc described and hang it. Barkeepers and 0000 steel wool is what I use and it takes rust right off. Wet the sign, sprinkle some on and work into a paste with a wet paper towel. Let sit 3-4 minutes and buff off with the steel wool. Don't let it sit more than that or it could dull your finish.
If you do go the fill and paint route, I'd suggest getting yourself a little hobbyists airbrush. The finish will come out smoother and thinner than a brush job and you can blend/fade it in to the surrounding area easier.
Posts: 24 |
Thanks to all of you for the information. This sign will be hung outside on an original swinging signpost 18 feet in the air so I need to stop the rust if I can. I have the original frame that it was mounted in. Jimmy
Posts: 649 |
I go along with the just clean it up and hang it up comments. Thats not that bad. I have a Mobiloil sign in my display with so many bullet holes in it that I have never bothered to count them.
It's one of my favorite pieces because I think it shows what really happened to a lot of them. Several visitors really like that sign; say it's really got character. Just my opinion.
To keep it from rusting further will be the problem. Not sure where you live in 'Carolina, but my experience with the weather, tells me good luck. Hot humid summers,cold wet,snowy winters and if you live near the coast salt water damage. A hard trio to fight with a sign aready showing "distress". I would suggest finding another sign that fits the bracket and hang your sign indoors. Either way, with a little "elbow grease" you will have a very fine and interesting "show piece", IMO. Please share photos of "before and after", we all do like photos.
Clean, wax & hang outside.
Posts: 858 |
You could clean it up, dab some of that rust killer chemical in each ding and spray a coat of good quality clear over it if you're set on puting it outside. That's the only sure way I can think of staving off the rust for any amount of time. If you use body filler and paint without something over it the paint will just fade out/wash away over time leaving you with pink (if you use spot putty) dots all over the sign. I'd leave the dings, clean up the rust stains and shoot some clear on it if it's going outside, otherwise just clean and hang in the garage (or your room of choice).
