#155662
Sun Oct 11 2009 06:42 PM
Posts: 1,192 |
PICKED UP A NICE LOAD OF PUMPS AND WAS LOOKING FOR SOME INFO ON A COUPLE OF NATIONAL PUMPS THAT WERE IN THE GROUP.THE FIRST PICTURE IS THE #2 PUMP FROM THE FRONT.THE SECOND PIC IS THE #3 PUMP FROM THE FRONT.THANKS.
Posts: 838 Likes: 11
Posts: 838 Likes: 11 |
Both are CUT DOWN NAT. A-38's
Posts: 1,689 Likes: 17
Posts: 1,689 Likes: 17 |
Agreed...seen the same thing done up here. A shame, really.
...I've never seen that before - looks like there's some good parts there...it's a shame no one makes repro sides and tops for A-38's, he'd be all set...
...what do the tops look like?...are they scalloped on the right and left, to line up with the sides?...
Posts: 1,192 |
CAST IRON TOPS WITH GLOBE HOLDERS.LOOK LIKE THEY WERE THERE FROM DAY ONE.THANKS
Petropumps, Yes & No. IF they hadn't been cut down, might have been scraped out.
I would look for a couple of Beaters to combine parts w/ these 2, OR get Creative an add A-62 TOPS to them.
Hey Mark, Look close at those tops. What do the corners of the tops look like? If they're shaped to match the contours of the sides, then maybe they were original...if they "hang over" the corners of the sides and don't match the contour, then I would continue to think they were cut-down. I've seen the exact same pump before on a farm up here and even had a very similar top...but you could tell by looking at the lines of the pump that it wasn't an original top. The A-38 sides are "layered" and the cast top didn't match those lines. What do yours look like??
Posts: 1,192 |
I WILL TAKE A CLOSE LOOK AT THE TOPS WHEN I GET BACK TO THE GARAGE.I AM 99% SURE THAT THESE TOPS WERE ON THESE PUMPS FROM DAY ONE.THEY MAY HAVE BEEN DESIGNED AS A38S AND FOR SOME REASON WERE CUT DOWN AND NEVER HAD THEIR GLASS TOP GLORY!THIS ENTIRE GROUP OF PUMPS HAVE BEEN IN CLOSED STORAGE FOR YEARS.THANKS FOR ALL THE INFO.MARK
Posts: 2,313 Likes: 86
Posts: 2,313 Likes: 86 |
Mark, Looks like you had a fun day! Did you gut the pumps on site or haul them with the guts? Could you post better pictures of the sides of the National pumps and top please? How is the top fastened? Is the teardrop side just appear to be cut short or does it have a shorter complete teardrop ?
Thanks, Rob
Posts: 1,192 |
ROB,I WILL GET SOME BETTER PICS WHEN I GET BACK TO THE GARAGE.THE PUMPS ARE ALL FULL.THEY WERE IN THE BACK OF A 45 FOOT TRAILER IN THE DARK WITH JUNK PILED UP IN FRONT OF THEM FOR YEARS.A GOOD FRIEND OF MINE WANTED ME TO DRIVE 6 HOURS ONE WAY AND LOAD THE PUMPS AND DRIVE BACK HOME!THAT IS WHAT WE DID!17 HOUR DAY!WE WERE SHOCKED WHEN WE SAW THE MESS.WE JUST ABOUT TURNED AROUND AND WENT HOME EMPTY.WE DECIDED TO GO FOR IT!THIS IS WHAT WE GOT.HARD WORK AND DETERMINATION CAN LOAD A TRAILER IN 5 HOURS!WE ALL KNOW ITS NOT ALWAYS EASY!FUN DAY?WELL,GOOD MEMORIES!I CAN PROMISE YOU WE WILL NEVER FORGET IT!MARK
...you're exhausted and filthy, you've got a load of old gas pumps, you hung out with a good buddy all day, and the smell of old stale gasoline fills the air (the smell of victory)...that's a good day...
Posts: 1,192 |
GULFIEND,VERY WELL SAID!THAT IS WHAT MAKES ALL OF IT WORTHWHILE!
Posts: 4,005 Likes: 7
Posts: 4,005 Likes: 7 |
Nice load there Mark, I have felt the way Mark has described.
How about a cut down A-1
Well I guess it would be a B-1 sense it is a clock face.
Posts: 1,192 |
OK GUYS,HERE ARE SOME MORE PICS OF THE NATIONAL PUMPS.SEE WHAT YOU THINK.THE ONLY #'S I CAN SEE ARE ON THE RED PUMP.LOOKS LIKE 39-1666.IT DOES HAVE OLD PHILLIPS 66 DECALS UNDER THE RED PAINT.DON'T KNOW IF THAT HAS ANYTHING AT ALL TO DO WITH THE #'S.ALSO THE 39 GOES ALONG WITH THE IDEA IT WAS BUILT OR MODIFIED AFTER THE 38.THE TOPS FIT REAL NICE AND ARE BOLTED DOWN THRU THE INSIDE OF THE GLOBE HOLDER BEST I CAN TELL WITHOUT SOME TEAR DOWN.LET ME KNOW WHAT YOU THINK.THANKS!HOPE YOU ALL HAVE A GREAT WEEK.MARK
Posts: 1,192 |
I've still gotta go with a cut-down A-38. What does the tag say on the red side?? The top just doesn't look right. The lines don't match-up like they should on the contours, and there's no reason that the top would go over the top tip of the nozzle receiver. I tell you what though, I have no idea what that top's off of and someone did one heck of a job cutting it down. I'd like to see a picture of the pump with the top off to see the tops of the sides. But I'm gonna stick with a cut-down.
If the company that was cutting them down did enough of them, they could of had a special top casting made. Then they re-numbered [model #] the pump.
Thanks for posting the extra pictures Mark. I agree with Dick a co. made a special mold then did the mods to make the pumps shorter to fit the later modern times. Funny at a glance looking at them from a distance they almost resemble a dayton pump in my opinion.
Posts: 294 |
How much work was involved in cutting down a pump?? It seems like a labor intense project and Im wondering why someone would go through all the trouble to cut one pump let alone several.
I've also seen Wayne 60's, 70's & Tok 39's cut off @ bottom.
