#124446 Tue Feb 19 2008 04:14 PM
O
oletymy Offline OP
O
Need the inspection doors for a gilbarco 87,they fit below the outer casting frame.
mona mike
#124447 Tue Feb 19 2008 07:07 PM
I thought only the G&B 86 had inspection doors below the bezel? My 87 has no inspection doors below the bezel. I was always told that's how you could tell 86 doors from 87 doors. No need for the doors on a clock pump. I've seen people weld in plates on the 86 doors to make them look like 87 doors when finished.
KJV Psalms 16:11
#124448 Tue Feb 19 2008 07:49 PM
O
oletymy Offline OP
O
this clock pump has got a hole in each door for a inspection plate.
mona mike
#124449 Tue Feb 19 2008 08:09 PM
I realize that but I think your doors have been swapped out sometime over the years with 86 doors. This is not un-common. The 87's never had the inspection doors, no need for them. I would weld in a patch to get rid of the opening and once the body work is done no one will know. I can post a pic. of my 87 doors w/o openings if needed.
KJV Psalms 16:11
#124450 Wed Feb 20 2008 05:18 AM
Mike is right 87's did not have inspection doors but you can make them out of sheet metal and get the clips for the 36B tokheim from gas pump heaven and make a nice copy. I think I have one to go buy if you need the measurements
Thanks Blair Underwood
704-485-8839
Petrolights
#124451 Wed Feb 20 2008 05:22 AM
I have an 87 and the doors are much shorter than the 86, were they all like this
Visit 15th Annual MASS GAS BASH
September 7th 2008
#124452 Wed Feb 20 2008 11:57 AM
Do not know what kind of 87 KZ1000 has but have measured 4 87 doors and 6 86 doors and all are just a shade over 86".
Thanks Blair
#124453 Wed Feb 20 2008 11:59 AM
Sorry for the typo, 66"
Blair
#124454 Wed Feb 20 2008 03:06 PM
O
oletymy Offline OP
O
thanks for everyones assistance, special thanks to Blair
mona mike
#124455 Wed Feb 20 2008 07:40 PM
For what it's worth, the GB 87 AR parts breakdown DOES show the pump as having two "Inspection" doors...
Ron
Ron Scobie
http://www.gaspump.com or
Phone - Six five one-653-6503
#124456 Wed Feb 20 2008 07:51 PM
Thanks Ron, I have 2 G&B 87 clockfaces and 3 86's, the 2 87's are at least 12" shorter than the 86's, and the one 87 with doors has the 2 inspection doors.
September 7th 2008
#124457 Fri Feb 22 2008 12:40 PM
Well, I've never seen a shorter 87. Sounds like you have 2 that have been cut down for some reason. I have had 86's and 87's and they are identical in height and width. It is possible to see 87's with the inspection doors since the pumps were made at the same time as the 86's. I guess G&B used which ever door was being run at the time. I will post a pic. of my 87 w/o inspection door. If you will look at an 87 though you will see that there would have been no use whatsoever for an inspection door below the face.
KJV Psalms 16:11
#124458 Fri Feb 22 2008 03:12 PM
O
oletymy Offline OP
O
Mike I could not agree with more there is no need for the inspection doors , But like Ron said the breakdown does show doors on the GB 87,
Mine is the GB 87 AR119
thanks for you input.
mona mike
#124459 Fri Feb 22 2008 03:14 PM
O
oletymy Offline OP
O
also the doors are 66 7/16" tall
mona mike
#124460 Sat Feb 23 2008 10:06 AM
Here's my 87 with No inspection doors. For what it's worth I also just missed another 87 that a local picker found. He sold it a few hours before I got there but I did look at it. It had No inspection doors either.
KJV Psalms 16:11
