Repop Socony Aircraft Sign #111564
Fri Jan 02 2004 10:46 PM
Columbus, GA
Globes and Signs Offline OP
Columbus, GA
Take a look at this sign item #3650638803
Re: Repop Socony Aircraft Sign #111565
Sat Jan 03 2004 07:10 AM
Big Valley, CA
Dwaine Buck Offline
Dwaine Buck  Offline
Big Valley, CA
Nice sign John , whats the question. if you look back in petroleum news, you will see at one of the bashes some found a hole stack of these. I think Jim posted pictures of the guy laying them on the ground and said they sold very fast. I couldn't find the pictures in the back issues.
[This message has been edited by Dwaine Buck (edited 01-03-2004).]
Re: Repop Socony Aircraft Sign #111566
Sat Jan 03 2004 07:11 AM
Mangum, OK USA
66phillips Offline
66phillips  Offline
Mangum, OK USA
I'm not a Standard expert, but it looks like a repop to me. The slick white back doesn't match the 20 by 30 inch ones. I wouldn't buy it with counterfeit money!
Re: Repop Socony Aircraft Sign #111567
Sat Jan 03 2004 07:39 AM
PECONIC BAY, L.I., NY, USA
THE AMERICAN GARAGE Offline
Here's my thoughts on this sign.... Notice
the edges are rounded off? How much corcern was there 70 years ago for a square pointy maybe dangerous sign that
supposedly came already installed on a
oil cabinet door? I smell a rat. I know that
in the early-mid 80's I bought repop signs from dealers that said the with todays lawsuits manufacturers couldn't put such a harsh point on some signs esp. arrow signs. Take that into consideration. The seller says he's had it for 25 years. I know of repops that are 30 years old! I've had a repop of this sign for about 10 years. The books say that this sign was made in two sizes: 20x30" and 12x20". make up your own minds!
DOC
[This message has been edited by THE AMERICAN GARAGE (edited 01-03-2004).]
Re: Repop Socony Aircraft Sign #111568
Sat Jan 03 2004 07:54 AM
Mangum, OK USA
66phillips Offline
66phillips  Offline
Mangum, OK USA
I was there when the big stash was laid out at Iowa Gas. The signs were all 20" by 30", and had pocked backs. I bought 4 of them. This seller says he believes it's origninal! No way this sign came out of the thirties..........
Butch
Re: Repop Socony Aircraft Sign #111569
Sat Jan 03 2004 10:13 AM
Big Valley, CA
Dwaine Buck Offline
Dwaine Buck  Offline
Big Valley, CA
We've had these discussions before about signs. and the different sign manufactures around the counrty, how each company does different things to their signs, we've tried to get some of you sign experts to help us with some dateing on EYELETS, and no one came forward. Just collectors talking amongst themselves found that the very early signs had no EYELET grommets, then came stainless steel gommets that star type in the back, but also in some areas the EYELET gommet were brass star type gommets. The rolled back grommet came around the 50ties an 60ties. could you comment on this for us Butch? the EYELET grommet, hes showing on this sign is stainless steel, with the star type back. I have never seen a reproduction sign with this type of grommet. but I've never seen them all. can we get some sign guys comments on this agin.
Re: Repop Socony Aircraft Sign #111570
Sat Jan 03 2004 10:25 AM
Mangum, OK USA
66phillips Offline
66phillips  Offline
Mangum, OK USA
I have some of the 20 by 30 inch Socony aircraft signs. None of them have the split back grommets. They have solid steel grommets. If you can get in a old bulk plant and find original old signs, it stands to reason that you can get in a old porcelain plant and find all kinds of grommets.
Re: Repop Socony Aircraft Sign #111571
Sat Jan 03 2004 10:28 AM
Columbus, GA
Columbus, GA
Butch is right at Iowa they were all 20"x30", and a totally different sign I bought a few as well. As for the grouments, that doesn't always tell the story. I have seen NUMEROUS repop signs where people have weathered them, and also took out the new grouments and replaces them with old ones. There is a lot more that goes into dating a sign than grouments.
Re: Repop Socony Aircraft Sign #111572
Sat Jan 03 2004 10:53 AM
Big Valley, CA
Dwaine Buck Offline
Dwaine Buck  Offline
Big Valley, CA
I wished one of you sign guys would write a piece on it for this site, so we can know what we are buying . as I've said, different areas had different ways of doing there signs. we've seen that with flying a signs. but we're all trying to learn thats why we come here to see if anything new has popped up. write something for us.
Re: Repop Socony Aircraft Sign #111573
Sat Jan 03 2004 10:57 AM
Mangum, OK USA
66phillips Offline
66phillips  Offline
Mangum, OK USA
The back of the sign will tell you more than what kind of grommets it has. I checked a 1939 Texaco No Smoking, and a 1946 Texaco Consignee. Both had splitback steel grommets. I checked a black Texas Company No smoking sign and it has solid steel grommets. I also checked a black Pennzoil bottle rack sign and it had split back brass grommets. I know it's as old as the heels. Go figure.
Re: Repop Socony Aircraft Sign #111574
Sat Jan 03 2004 11:55 AM
Davenport Iowa
Greg Aust Offline
Greg Aust  Offline
Davenport Iowa
I know this may be a hassle but could someone post photos of the different grommits to look at?
Re: Repop Socony Aircraft Sign #111575
Sat Jan 03 2004 11:58 AM
Big Valley, CA
Dwaine Buck Offline
Dwaine Buck  Offline
Big Valley, CA
Your right Butch, different sign companys that got the contracts to do sign for different oil companys used different ways of doing things. so you might look at signs made in Canada from 1941 thru 1945 and they are different from what was made here before and after the war. Signal in 1931 when they started their gasoline division, the first door signs with the two red lights did not have grommets. but the later ones with the two red lights did.
The point being, theres guys that go by the grommet only. there are the ones that go by the pointed corners, or rounded ones, the backs . the thickness. we have put two Flying a sign togather from the same era and ones a creamy ones white ,white. ones corners are not as pointy as the other, two different sign companys. the bigger the company the more confuseing there signs are, thats why when a sign comes on that I question I email you or Keith. can't get you most of the time your always in someones barn. or pulled up to their table, ha ha just kidding. we need a good book on signs , not just pictures but information. Seth is doing it now but there are a lot of repos that you can't tell, but hes marking them good. and we need that. and the repo globes , I've said it before and I'll say it agin . the west coast companys never made a 13 1/2 " globe. tidewater was the only one on the west coast in the last years that might have. and we (all of us) have not seen it all yet. Up pops a little ol Micraphone sign from Associated and all the big guys goes nuts. how about the Beacon signs that showed up at Fred's . everybody but one standing around scratching him self looking and one guys steps up , ha ha oh Butch that same guy has 4 more. but hes not as dumb this time. have a nice day guys.
Re: Repop Socony Aircraft Sign #111576
Sat Jan 03 2004 12:48 PM
illinois
Lastgas15 Offline
Lastgas15  Offline
illinois
Dwaine,
I've figured out one thing about globes. NEVER say never! You might be right that west coast companies didn't use 13 1/2" globes, but new discoveries pop up all the time.
Rumor is there might be a new sign book in the works. I'd say a GOOD sign book is long overdue!
http://www.lastgas15.com/
Re: Repop Socony Aircraft Sign #111577
Sat Jan 03 2004 04:14 PM
Big Sky Country
minuteman Online content
minuteman  Online Content
Big Sky Country
In my 1988 Weber's catalogue shows the IDENTICAL porcelain sign 10 x 14 inch selling for 16.95. I'm with Butch...there is NO WAY this is an old original sign...
petro, farm, auto, etc.
Re: Repop Socony Aircraft Sign #111578
Sat Jan 03 2004 04:52 PM
Columbus, GA
Columbus, GA
Dwaine,
I am with Bob, never say never Clipper is out of Seattle and they made a 13.5" globe.
Copyright © 2019 Primarily Petroliana Interactive, All Rights Reserved
Page Time: 0.017s Queries: 13 (0.004s) Memory: 3.2182 MB (Peak: 3.4772 MB) Zlib disabled. Server Time: 2019-06-24 19:22:43 UTC
